Component: IO Expander (Comms: System)
Revision as of 08:43, 17 October 2024 by MartinW (talk | contribs) (→‎Examples)
Category Comms: System
IO Expander component
Provides 16 digital input/output pins arranged into two 8-bit ports using a SPI bus connection. Multiple expanders can be connected to the same SPI peripheral by means of individual chip select pins.
More information on I2C can be found here,
Generic I2C EEPROM
Example file demonstrating how to read and write bytes from a generic I2C EEPROM device. FC6 Icon.png I2CEEPROM
Fc9-comp-macro.png ReadPort
Reads a value to one of the ports with a mask. Configures the masked bits to be inputs before reading the input value.
Fc9-u8-icon.png - BYTE Port
0=PortA, 1=PortB
Fc9-u8-icon.png - BYTE Mask
Allows port bits to be modified without effecting other bits, 255 = write full port.
Fc9-comp-macro.png ConfigureInversion
Configures the pin inversion for the two ports. Disabled on all pins by default.
Fc9-u8-icon.png - BYTE PortA
Port A inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
Fc9-u8-icon.png - BYTE PortB
Port B inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
Fc9-comp-macro.png ReadPortPin
Reads a single port pin from one of the ports. Configures the pins to be an input before reading the input value. Returns 0 or 1 corresponding to the value on the port pin.
0=PortA, 1=PortB
Fc9-u8-icon.png - BYTE Pin
Port pin to read. Range: 0-7
Fc9-comp-macro.png WritePortPin
Writes a single port pin on one of the ports. Configures the pins to be an output before writing the input value.
0=PortA, 1=PortB
Fc9-u8-icon.png - BYTE Value
Value to output on the selected pin. Range: 0-1
Writes a value to one of the ports with a mask. Configures the masked bits to be outputs before writing the output value.
0=PortA, 1=PortB
Value to write. Range 0-255
Fc9-comp-macro.png ConfigurePullups
Configures the pullups for the two ports. Disabled on all pins by default.
Port A pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
Port B pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
Fc9-comp-macro.png ReadRegister
Reads an 8-bit value from a register on the I/O expander device.
Register address to write to. Range: 0-15
Fc9-comp-macro.png WriteRegister
Writes an 8-bit value to a register on the I/O expander device.
Value to write. Range: 0-255
Fc9-comp-macro.png Initialise
Enables the I²C hardware and performs some initialization. Should be called at the start of the program or at least before any of the other I²C functions are called.
Fc9-comp-macro.png CheckNetworkStatus
Returns the state of the GSM network. 0 = Not connected, 1 = connected, 255 = no reply from GSM.
Fc9-comp-macro.png CheckForIncoming
Checks to see if any incoming phone call or SMS message. 0 = Nothing, 1 = Text Received, 2 = Phone Ringing
Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail.
Fc9-type-16-icon.png External Address
Selects the value of the three address pins for the MCP23S17.
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-type-7-icon.png Use Reset
Fc9-conn-icon.png Simulations
Fc9-type-10-icon.png Label
Fc9-type-16-icon.png API
