Component: DC Motor (Mechatronics)
| Version | 1.2 |
| Category | Mechatronics |
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Version information
Library Version, Component Version, Date, Author, Info 2, 1.2, 13-11-24, BR, Altered property tooltips to make them more meaningful
Simple example showing how to drive the motor component by only using Enable and two port pins.
Break
| Break | |
| Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property. | |
Coast
| Coast | |
| Turn off power to the motor by setting the pins according to the 'Coast Pattern' property. | |
Disable
| Disable | |
| Disable the motor output | |
Enable
| Enable | |
| Enables the motor output | |
Forwards
| Forwards | |
| Set the motor turning in the forwards direction by setting the pins according to the 'Forwards Pattern' property. | |
| Duty | |
| Sets the motor power for PWM or H-Bridge outputs | |
GetSimAngle
| GetSimAngle | |
| Gets the angle of the simulated motor shaft in degrees. | |
Reverse
| Reverse | |
| Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property. | |
| Duty | |
Please click here to download the component source project: FC_Comp_Source_DCMotor_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DCMotor_2d.fcfx
