Component: Quadrature Encoder (General Input)
| Version | 1.5 |
| Category | General Input |
Quadrature Encoder component
Quadrature Encoder component implements a rotary encoder connected to two pins. Quadrature Encoders provides incremental positioning rather than absolute positioning.
Version information
Library Version, Component Version, Date, Author, Info 6, 1.5, 26-11-24, BR, Updated tooltip for CheckForChanges macro
Mechanical encoders can be a bit electrically noisy when switching and so to have reliable operation it is recommended to have a simple filter as shown here.
Polling
Example program showing how to use a quadrature encoder component using a polling method.
 Quad_Encoder_Test
Quad_Encoder_Test
Timer Interrupt Based Polling
Example program showing how to use a quadrature encoder component using a polling method via a timer interrupt.
 Quad_Encoder_Timer
Quad_Encoder_Timer
Interrupt On Change
Example program showing how to use a quadrature encoder component using a interrupt on pin state change interrupt (IOC).
 Quad_Encoder_IOC
Quad_Encoder_IOC
CheckForChanges
|   | CheckForChanges |
| Polling function to check changes and update internal counter. Returns 1 for chaged, 0 for no change, 255 for error | |
|  - BYTE | Return |
Disable
|   | Disable |
| Disables the use of the quad encoder Once this ist called, the read functions will return zeros until the next Enable() call | |
|  - VOID | Return |
Enable
|   | Enable |
| Enables the use of the quad encoder If this is not called, the read functions will return zeros | |
|  - VOID | Return |
ReadCounter
|   | ReadCounter |
| Reads the current dial counter This is a counter from -32768 to 32767 | |
|  - INT | Return |
ReadCounter32
|   | ReadCounter32 |
| Reads the current dial counter as a 32-bit value This is a counter from -2147483648 to 2147483647 | |
|  - LONG | Return |
ResetCounter
|   | ResetCounter |
| Resets the current dial counter to zero | |
|  - VOID | Return |
Rotate
WriteCounter
|   | WriteCounter |
| Sets the value of the internal count variable. Range: -32768 to 32767 | |
|  - INT | Value |
|  - VOID | Return |
WriteCounter32
|   | WriteCounter32 |
| Sets the value of the internal count variable. Range: -2147483648 to 2147483647 | |
|  - LONG | Value |
|  - VOID | Return |
Please click here to download the component source project: FC_Comp_Source_Encoder_Quadrature.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Encoder_Quadrature.fcfx
