Component: Temp / Humidity (Grove 101020212) (101020212) (Environmental)
| Version | 2.0 |
| Category | Environmental |
Temp / Humidity (Grove 101020212) component
Humidity and temperature sensor using an SHT31 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
An example displaying real temperatures and humidity using floats,
Grove 101020212 (SHT31) Example
GetHumidityData
| GetHumidityData | |
| Returns the raw register pair value | |
GetHumidityInt
| GetHumidityInt | |
| returns the relative Humidity reading as an integer value | |
GetHumidityReal
| GetHumidityReal | |
| returns the Humidity reading as a float value | |
GetTemperatureData
| GetTemperatureData | |
GetTemperatureInt
| GetTemperatureInt | |
| Return temperature reading as an integer value in degrees C | |
GetTemperatureReal
| GetTemperatureReal | |
| Return temperature reading as a float value in degrees C | |
Please click here to download the component source project: FC_Comp_Source_Humidity_SHT31_Grove.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Humidity_SHT31_Grove.fcfx
