Component: COM Port (Runtime Tools)
Revision as of 08:58, 9 June 2025 by Wiki bot (talk | contribs)
Version 103.11
Category Runtime Tools
COM Port component
Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial.
Version information
11, 103.11, 01-05-25, BR, Changed SendString macro to make it more efficient
Auto Detect Port Number
This example auto detects and opens a COM Port based on preassigned USB Identifiers VID/PID.
For a known device the VID and PID can be found via Windows device manager.
FC6 Icon.png Auto Detect Example
ClosePort
Fc9-comp-macro.png ClosePort
Closes the currently open COM port, ending communications and allowing it to be accessed via another application.
ConfigureConsole
Fc9-comp-macro.png ConfigureConsole
Fc9-u8-icon.png - BYTE Status
GetConsoleHandle
GetProp
Fc9-comp-macro.png GetProp
Allows the property filter for the COM port list to be copied to a parent component.
Fc9-string-icon.png - STRING PropName
OpenPort
Fc9-comp-macro.png OpenPort
Opens the currently selected COM port, allowing data to be sent and received.
ReceiveBinary16Bit
Fc9-comp-macro.png ReceiveBinary16Bit
Receives a binary 16-bit value split across two bytes.
Fc9-bool-icon.png - BOOL MSBfirst
0=Least significant byte first, 1=Most significant byte first
Fc9-u8-icon.png - BYTE Timeout
Max amount of time in ms to wait between bytes
ReceiveBinary32Bit
Fc9-comp-macro.png ReceiveBinary32Bit
Receives a binary 32-bit value split across four bytes.
Fc9-u32-icon.png - ULONG Return
ReceiveBinaryFloat
Fc9-comp-macro.png ReceiveBinaryFloat
Receives a binary 32-bit floating point value split across four bytes.
ReceiveByte
Fc9-comp-macro.png ReceiveByte
Attempts to receive a byte using the COM port No valid return data is provided by the timeout value property.
Fc9-u16-icon.png - UINT Timeout
Time to wait for incoming data in milliseconds
ReceiveByteArray
Fc9-comp-macro.png ReceiveByteArray
Attempts to receive an array of bytes using the COM port Returns the number of bytes received.
Fc9-u8-icon.png - BYTE Data
Fc9-u16-icon.png - UINT MaxLength
Max number of bytes to try and read
ReceiveFloat
Fc9-comp-macro.png ReceiveFloat
Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
Max time in ms to wait in between bytes
Fc9-bool-icon.png - BOOL IgnoreData
0=Dont ignore any data, 1=Ignore any initial none numeric data
ReceiveHexNumber
Fc9-comp-macro.png ReceiveHexNumber
Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
Fc9-bool-icon.png - BOOL Prefix
Look for prefix before receiving, 1=0xFF, 0=FF
ReceiveINTArray
Fc9-comp-macro.png ReceiveINTArray
Receives an array of 16-bit INT/UINT values and returns the number of values received.
Fc9-u16-icon.png - UINT Data
Array to store the incoming data
Fc9-u16-icon.png - UINT NumValues
Maximum number of values to try and receive
Fc9-s16-icon.png - INT Return
ReceiveNumber
Fc9-comp-macro.png ReceiveNumber
Attempts to receive a number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
ReceiveString
Fc9-comp-macro.png ReceiveString
Attempts to receive a string using the COM port. MaxLength sets the maximum number of bytes that can be received, Timeout is the max time between characters.
ReceiveStringWithTermination
Fc9-comp-macro.png ReceiveStringWithTermination
Attempts to receive an string using the COM port. Will return if the selected termination characters are received. Returns the number of bytes received.
Fc9-string-icon.png - STRING Termination
String to check for to terminate the receive.
Fc9-u8-icon.png - BYTE TerminationLength
ScanForDeviceID
Fc9-comp-macro.png ScanForDeviceID
Checks to see if a device VID/PID string is present and returns the COM port number. Returns 0 if device not found.
Fc9-string-icon.png - STRING HWID
Example: "VID_12BF&PID_0101"
ScanForDeviceIDEx
Fc9-comp-macro.png ScanForDeviceIDEx
Checks to see if a device VID/PID string is present and returns the COM port number, allows multiple devices with the same details to be detected. Returns 0 if device not found.
Fc9-u8-icon.png - BYTE SkipCount
0=Returns first match, 1=Returns second match etc.
Fc9-bool-icon.png - BOOL ScanForDevId
0=Scan PID/VID / 1=Scan DeviceID
SendBinary16Bit
Fc9-comp-macro.png SendBinary16Bit
Sends out a 16-bit binary value split across two bytes.
Fc9-u16-icon.png - UINT Value
SendBinary32Bit
Fc9-comp-macro.png SendBinary32Bit
Sends out a 32-bit binary value split across four bytes.
Fc9-u32-icon.png - ULONG Value
SendBinaryFloat
Fc9-comp-macro.png SendBinaryFloat
Sends out a 32-bit binary floating point value split across four bytes.
SendByte
Fc9-comp-macro.png SendByte
Sends a single byte to be sent out via the COM port.
SendByteArray
Fc9-comp-macro.png SendByteArray
Sends an array of bytes to the COM port.
Data byte array to send
Number of bytes to send
SendFloat
Fc9-comp-macro.png SendFloat
Sends out a floating point number as an ASCII String from the UART interface.
Fc9-f32-icon.png - FLOAT Number
SendHexNumber
Fc9-comp-macro.png SendHexNumber
Sends out a number as an ASCII hexadecimal String from the UART interface.
Fc9-u32-icon.png - ULONG Number
Fc9-u8-icon.png - BYTE NumChars
Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
SendINTArray
Fc9-comp-macro.png SendINTArray
Transmits an array of 16-bit INT/UINT values via the UART peripheral
Data to transmit
Number of 16-bit values to send from the array
SendNumber
Fc9-comp-macro.png SendNumber
Sends out a number as an ASCII String from the UART interface.
Fc9-s32-icon.png - LONG Number
SendString
Fc9-comp-macro.png SendString
Sends an string of characters to the COM port.
SetDTRState
Fc9-comp-macro.png SetDTRState
Allows the DTR signal to be enabled or disabled.
Fc9-u8-icon.png - BYTE State
A value of 0 disables the DTR, 1 or above willl enable the DTR.
SetFlowControl
Fc9-comp-macro.png SetFlowControl
Allows the Flowcontrol signals to be enabled or disabled.
A value of 0 disables flow control, 1 or above willl enable flow control.
SetProp
Fc9-comp-macro.png SetProp
Allows the COM port property to be set from a parent component.
Fc9-u32-icon.png - ULONG PropVal
Fc9-type-16-icon.png COM Port
Selects which port to communicate with, only lists ports which are currently available.
Fc9-type-7-icon.png Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Fc9-type-14-icon.png Baud
Baud rate passed to the COM port to control the rate of data.
Fc9-type-14-icon.png Timeout Value
Value to specify what is returned when no incoming receive data is present.
Fc9-type-7-icon.png Auto Close
Auto close the port on Sim stop event
Fc9-type-16-icon.png New Line Format
Please click here to download the component source project: FC_Comp_Source_COM_Port.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_COM_Port.fcfx
