Component: Combo (BL0114) (E-blocks 2)
Revision as of 08:58, 9 June 2025 by Wiki bot (talk | contribs)
Category E-blocks 2
Combo component
A component to drive the BL0114 Combo board including LEDs, Switches, LCD, 7-Segs and analogue inputs.
Creates a standard stopwatch with 0.01 second accuracy complete with start/stop/restart functionality.
Displays using the 7-segment displays on the BL0114 Combo
Combo connected to Ports A and B
A4 Start / Stop - A5 Reset
FC6 Icon.png Combo 7-Seg Timer
IO_GetPort
Fc9-comp-macro.png IO_GetPort
Reads the state of a single port
Fc9-u8-icon.png - BYTE Bank
0 = Top Bank of Switches, 1 = Bottom Bank of Switches
IO_GetSwitchState
Fc9-comp-macro.png IO_GetSwitchState
Reads the state of a single switch Returns: 0 = Switch not pressed, 1 = Switch pressed
Fc9-u8-icon.png - BYTE Switch
0 = SW0, 7 = SW7
IO_ReadAnalogAsByte
Fc9-comp-macro.png IO_ReadAnalogAsByte
Reads one of the analogue components as an byte value
0 = Light Sensor, 1 = Potentiometer
IO_ReadAnalogAsInt
Fc9-comp-macro.png IO_ReadAnalogAsInt
Reads one of the analogue components as an Integer value
Fc9-s16-icon.png - INT Return
IO_SetLEDState
Fc9-comp-macro.png IO_SetLEDState
Sets the state of a single LED
0 = Top Bank of LEDs, 1 = Bottom Bank of LEDs
Fc9-u8-icon.png - BYTE LED
0 = LED0, 7 = LED7
Fc9-u8-icon.png - BYTE State
0 = Off, 1 = On
IO_SetPort
Fc9-comp-macro.png IO_SetPort
Sets the state of a single port
Fc9-u8-icon.png - BYTE Value
LCD_Clear
Fc9-comp-macro.png LCD_Clear
LCD_ClearLine
Fc9-comp-macro.png LCD_ClearLine
Fc9-u8-icon.png - BYTE Line
The line to clear, zero being the first (top) line of the display
LCD_Command
Fc9-comp-macro.png LCD_Command
Fc9-u8-icon.png - BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
LCD_Cursor
Fc9-comp-macro.png LCD_Cursor
Fc9-u8-icon.png - BYTE x
Set the cursor position in the X plane, 0 is the left most cell
Fc9-u8-icon.png - BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
LCD_PrintAscii
Fc9-comp-macro.png LCD_PrintAscii
Fc9-u8-icon.png - BYTE character
Holds an ascii value.
LCD_PrintFloat
Fc9-comp-macro.png LCD_PrintFloat
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE DecimalPlaces
LCD_PrintFormattedNumber
Fc9-comp-macro.png LCD_PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
LCD_PrintNumber
Fc9-comp-macro.png LCD_PrintNumber
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
LCD_PrintString
Fc9-comp-macro.png LCD_PrintString
Enter the text or variable to print to the LCD
LCD_RAMWrite
Fc9-comp-macro.png LCD_RAMWrite
Fc9-u8-icon.png - BYTE Index
Values 0 to 7
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
LCD_RawSend
Fc9-comp-macro.png LCD_RawSend
Sends data to the LCD display
Fc9-u8-icon.png - BYTE data
The data byte to send to the LCD
Fc9-bool-icon.png - BOOL type
A boolean to indicate command type: true to write data, false to write a command
LCD_RemapCharacter
Fc9-comp-macro.png LCD_RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
Fc9-u8-icon.png - BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
Fc9-u8-icon.png - BYTE SearchCharacter
Character to look for a replace
Fc9-u8-icon.png - BYTE ReplacementCharacter
New character value to use in place of the search character.
LCD_ScrollDisplay
Fc9-comp-macro.png LCD_ScrollDisplay
Fc9-u8-icon.png - BYTE Position
Holds the number of positions to shift the display
Fc9-u8-icon.png - BYTE Direction
0 = left, 1 = right
LCD_Start
Fc9-comp-macro.png LCD_Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Seg_ShowDigit
Fc9-comp-macro.png Seg_ShowDigit
Displays a digit on the 7-seg display
Fc9-u8-icon.png - BYTE Digit
Which of the digits to change (0 - 3)
The value to display (0 - 9)
Fc9-u8-icon.png - BYTE DecimalPoint
Decides if the decimal point is lit
Seg_ShowSegments
Fc9-comp-macro.png Seg_ShowSegments
Allows the individual segments of the display to be controlled.
Fc9-u8-icon.png - BYTE Segments
8-bit Binary value to set the segments, bit0 = segA, bit1 = segB...
Fc9-type-16-icon.png Connection Type
Fc9-conn-icon.png Bank 0 Connections
Fc9-type-19-icon.png Bank 0
Fc9-conn-icon.png Bank 1 Connections
Fc9-type-19-icon.png Bank 1
Fc9-conn-icon.png Analog Connections
Fc9-type-6-icon.png Light Sensor
Light Sensor ADC channel Connected to Bank 0 pin 0 which is usually analog pin AN0.
Fc9-type-6-icon.png Potentiometer
Potentiometer ADC channel Connected to Bank 0 pin 1 which is usually analog pin AN1.
Fc9-conn-icon.png Simulation
Fc9-type-7-icon.png Analog Scope Traces
Controls if traces are automatically added to the data recorder window for the analogue signals on the combo board.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_COMBO_BL0114.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_COMBO_BL0114.fcfx
