Component: LED (BL0167) (E-blocks 2)
| Version | 7.7 |
| Category | E-blocks 2 |
LED component
LED component to drive the E-blocks 2 BL0167 LED board. Provides eight individually addressable LEDs.
Version information
Library Version, Component Version, Date, Author, Info 7, 7.0, 23-04-25, MW, Hidden propert to change LED colours as the LEDS on the BL0167 are red 8, 7.0, 08-05-25, BR, Added autodetect port on Ev_PostInitialise
AllOff
|   | AllOff |
| Switches Off All LEDs. | |
|  - VOID | Return |
AllOn
|   | AllOn |
| Switches On All LEDs. | |
|  - VOID | Return |
BarGraph
|   | BarGraph |
| Turns on the first N elements of the array - for generating bar graph metes etc. | |
|  - BYTE | Length |
| How many items to light up. Range 0-8 | |
|  - VOID | Return |
LEDOff
|   | LEDOff |
| Turns off the selected LED leaving the other LEDs as was. | |
|  - BYTE | Index |
| LED to switch off. Range: 0-7 | |
|  - VOID | Return |
LEDOn
|   | LEDOn |
| Turns on the selected LED leaving the other LEDs as was. | |
|  - BYTE | Index |
| LED to switch on. Range: 0-7 | |
|  - VOID | Return |
PointGraph
|   | PointGraph |
| Turns on the Indexed LED and turns all others off. Does nothing if the index is out of range. | |
|  - BYTE | Index |
| The LED to light. Range: 0-7 | |
|  - VOID | Return |
WriteValue
|   | WriteValue |
| Write a number which is presented on the LEDs in binary. | |
|  - BYTE | Value |
| Value to write to the LEDs. Range: 0-255 | |
|  - VOID | Return |
|   | Properties |
|   | Output Mode |
|   | Port |
Please click here to download the component source project: FC_Comp_Source_EBlocks2_LED_BL0167.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_LED_BL0167.fcfx
