Author
Matrix Ltd
Version
1.4
Category
Graphical Monochrome
GLCD (KS0108) component
Graphical display component designed to work with the KS0108 type monochrome displays. Also compatible with the newer S6A0107 controller IC displays.
Version information
BPlot
BPlot
- UINT
X1
- UINT
Y1
ClearDisplay
ClearDisplay
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT
X
Center X coordinate
- UINT
Y
Center Y coordinate
- UINT
Radius
Radius, distance of edge from the centre coordinates
- FLOAT
StartAngle
Angle to start drawing, in degrees
- FLOAT
EndAngle
Angle to end drawing, in degrees
- UINT
Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE
Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE
Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Draws a rectangle with rounded corners
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetBackgroundColour
SetBackgroundColour
- BYTE
Pixel_Colour
0=White, 1=Black
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
Pixel_Colour
0=White, 1=Black
Dimensions
Pixel Width
Pixel Height
Controller Count
Speicifies the number of controller IC's built into the display and therefore the number of available chip select pins
Colour
Monochrome
Foreground Color
Background Colour
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
CS1
Chip select to address the first controller IC
CS2
Chip select to address the second controller IC
RS
Data / Instruction register select pin.
RW
Read / write select pin
Enable
Data enable to clock a command or data in or out of the device
Data0
Data Pin 0
Data1
Data Pin 1
Data2
Data Pin 2
Data3
Data Pin 3
Data4
Data Pin 4
Data5
Data Pin 5
Data6
Data Pin 6
Data7
Data Pin 7
Reset
Display reset pin
Fonts
Font Count
Font 0
Font
Bytes Required
Number of bytes required in program memory to store the selected font.
Character Spacing
Sets the number of blank pixels between each character when printing text.
Space Width
Component Label
Component Label Scale
Physical Orientation
Display Delay
Enable Delay
Time in micro seconds to wait before and after toggling the enable pin.
Please click here to download the component source project: FC_Comp_Source_GLCD_KS0108.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_KS0108.fcfx
