Component: Temp / Humidity (SHT41 / BL0144) (Environmental)
| Category | Environmental |
Temp / Humidity (SHT41 / BL0144) component
Humidity and temperature sensor using an SHT41 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
An example displaying real temperatures and humidity using floats,
Grove 101020212 (SHT31) Example
ChangePrecision
GetHumidityInt
| GetHumidityInt | |
| returns the relative Humidity reading as an integer value | |
GetHumidityReal
| GetHumidityReal | |
| returns the Humidity reading as a float value | |
GetTemperatureInt
| GetTemperatureInt | |
| Return temperature reading as an integer value in degrees C | |
GetTemperatureReal
| GetTemperatureReal | |
| Return temperature reading as a float value in degrees C | |
SetTemperatureScale
| SetTemperatureScale | |
| Sets the temperature scale to celcius or farenheit Default: Celcius | |
| Scale | |
| 0=Celcius, 1=Farenheit | |
Please click here to download the component source project: FC_Comp_Source_Humidity_SHT41.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Humidity_SHT41.fcfx
