Component: Thermocouple (MAX31856) (Environmental)
Revision as of 08:59, 9 June 2025 by Wiki bot (talk | contribs)
Category Environmental
Thermocouple (MAX31856) component
Component to interface the MAX31856 IC from MAXIM. Uses a standard 4-wire SPI interface to connect to the IC and collect the temperature. Compatible with different thermocouple types.
Fc9-comp-macro.png Initialise
Configures the SPI bus ready for communications.
ReadReference_Float
Fc9-comp-macro.png ReadReference_Float
Returns the reference temperature from the last sample as a floating point value in Degrees C.
ReadReference_Int
Fc9-comp-macro.png ReadReference_Int
Returns the reference temperature from the last sample as an integer value in Degrees C.
Fc9-s16-icon.png - INT Return
ReadThermocouple_Float
Fc9-comp-macro.png ReadThermocouple_Float
Returns the thermocouple temperature from the last sample as a floating point value in Degrees C.
ReadThermocouple_Int
Fc9-comp-macro.png ReadThermocouple_Int
Returns the thermocouple temperature from the last sample as an integer value in Degrees C.
Sample
Fc9-comp-macro.png Sample
Reads the memory of the MAX31855 IC and checks for errors. Must be called before any of the Read functions. Returns: 0=OK, 1=Open Circuit, 2=Under/Over Voltage, 3=Out of range
WriteColdJunctionOffset
Fc9-comp-macro.png WriteColdJunctionOffset
When Cold Junction Compensation is enabled mode this macro allows you to define the offset temperature of the cold junction.
Fc9-f32-icon.png - FLOAT OffsetTemperature
Range: +/- 7 Degrees
WriteColdJunctionTemperature
Fc9-comp-macro.png WriteColdJunctionTemperature
When Cold Junction Compensation is disabled/external mode this macro allows you to define the temperature of the cold junction.
Fc9-f32-icon.png - FLOAT Temperature
Range: +/- 127 Degrees
Fc9-conn-icon.png Thermocouple Properties
Fc9-type-16-icon.png Thermocouple Type
Specified the thermocouple type used with the sensor IC
Fc9-type-16-icon.png Averaging
Select the number of samples used to provide stable readings.
Fc9-type-16-icon.png Conversion Mode
Fc9-type-16-icon.png Notch Filter
Choose the frequency of notch filter
Fc9-type-16-icon.png Cold Junction Compensation
Allows the chip to automatically perform cold junction compensation to try and get more accurate temperature conversions. Internal - Uses internal temperature sensor External / Disabled- Uses SetColdJunctionTemperature macro to allow for external temperature compensation.
Fc9-conn-icon.png SPI Properties
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-conn-icon.png Simulation
Please click here to download the component source project: FC_Comp_Source_ThermocoupleMAX31856.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ThermocoupleMAX31856.fcfx
