Supporting Third Party Programming Tools
Revision as of 09:59, 29 August 2025 by MartinW (talk | contribs)
Each version of Flowcode comes ready with a default programming tool. However it is fairly easy to change the settings in Flowcode to allow for third party programming tools to be used.
The programming tool that is invoked when the compile to chip button is pressed is configured in the Build menu under Compiler options then click on the Programmer tab page.
For help with third party programming tools the first port of call should be to check our forums to see if anyone else has already tried the programming tool with Flowcode. If you are the first then if you wish you can post your findings for other users to benefit from.
Warning
Editing the Compiler or Linker tabs of the compiler options will likely stop Flowcode from being able to compile correctly unless you know what you are doing.
The settings below are for the Programmer tab of the compiler options. Take care to ensure you only edit the values in the Programmer tab.
If you do edit the values in the compiler or linker tab then you can simply revert back to the default settings and start again.
Microchip PIC / PIC16 / PIC32
mLoader
mLoader is the default programming software and can be used to talk to the various Matrix hardware including E-blocks, E-blocks2, Formula Flowcode, ECIO, MIAC, ProtoBoard, ProjectBoard...
Parameters:
-chip $(chip:u) "$(outdir)$(target).hex"
PPP
PPP is the older programming software from Flowcode v5 and previous and can be used to talk to versions of the E-blocks EB006 up to and including version 8.
$(appdir)tools\PPP\PPPv3.exe
Parameters:
-cs 2 -chip PIC$(chip:u) -nogui "$(outdir)$(target).hex"
PICkit2
$(appdir)tools\PICkit2\pk2cmd.exe
Parameters:
-B$(appdir)tools\PICkit2\ -PPIC$(chip) -F$(target).hex -M -A5 -R
Details on how to upgrade your PICkit 2 to work with new targets are available from here.
Please note that the PICkit 2 was never designed to work with the newer devices and although it is known to work, you may cause damage to your PIC devices by using incorrect VPP programming voltages etc as supplied by the PICkit 2.
PICkit3 - PK3CMD (OLD)
There are two options for using the PICkit 3 depending on how you are powering your hardware:
Powered externally
$(appdir)tools\PICkit3\PK3CMD.exe
Parameters (8-bit PIC):
-P$(chip) -F$(target).hex -E -M
Parameters (16-bit PIC):
-P$(chip) -F$(target).hex -E -M -L
Powered via the PICkit
-P$(chip) -F$(target).hex -V5 -E -M
-P$(chip) -F$(target).hex -V3.3 -E -M -L
Please note that the PICkit 3 will fail to program if you have spaces in your Flowcode project name, replacing spaces with underscores or removing them completely should resolve the issue.
Also note that if your using the PICkit 3 with MPLABX or have bought a new one recently then you will likely have to downgrade the firmware to allow Flowcode to work with the PICkit.
Full details on how to do this are available from here.
If your still having problems getting the PICkit 3 to fire up then this forum topic may be of help.
PICkit3 - IPE (NEW)
First make sure you have the latest MPLAB X installed on your computer. We used version 4.20 which is used in the location path shown below. Make sure your path matches your installed location.
Powered externally
$(mplabxdir)mplab_platform\mplab_ipe\ipecmd.exe
Parameters:
/P$(chip) /F"$(outdir)$(target).hex" /TPPK3 /M /OL
Parameters - Powered at 3V3:
/P$(chip) /F"$(outdir)$(target).hex" /TPPK3 /M /OL /W3.3
Parameters - Powered at 5V:
/P$(chip) /F"$(outdir)$(target).hex" /TPPK3 /M /OL /W5
To use the Microchip Real ICE programmer instead of the PICkit 3 substitute the parameter /TPPK3 with /TPRICE
PICkit4
Version 4.20 is the minimum version that will work with the PICkit 4 hardware.
There are two options for using the PICkit 4 depending on how you are powering your hardware:
Powered externally
Parameters:
/P$(chip) /F"$(outdir)$(target).hex" /TPPK4 /M /OL
/P$(chip) /F"$(outdir)$(target).hex" /TPPK4 /M /OL /W3.3
/P$(chip) /F"$(outdir)$(target).hex" /TPPK4 /M /OL /W5
SNAP
First make sure you have the latest MPLAB X installed on your computer. We used version 5.40 which is used in the location path shown below. Make sure your path matches your installed location.
Version 5.40 is the minimum version that will work with the Snap hardware.
There are two options for using the Snap depending on how you are powering your hardware:
Powered externally
Parameters:
/P$(chip) /F"$(outdir)$(target).hex" /TPSNAP /M /OL
/P$(chip) /F"$(outdir)$(target).hex" /TPSNAP /M /OL /W3.3
/P$(chip) /F"$(outdir)$(target).hex" /TPSNAP /M /OL /W5
ICD3
There are two options for using the ICD3 depending on how you are powering your hardware:
Powered externally
Parameters:
/P$(chip) /F"$(outdir)$(target).hex" /TPICD3 /M /OL
Powered via the ICD3
/P$(chip) /F"$(outdir)$(target).hex" /TPICD3 /M /OL /W3.3
/P$(chip) /F"$(outdir)$(target).hex" /TPICD3 /M /OL /W5
FS USB
Flowcode PIC comes with a example for using the free microchip USB bootloader. Changing your target to the MCHP_FSUSB will automatically configure the programmer to use the Microchip PDFSUSB programming tool. Note - The USB bootloader firmware must be present on the device to allow the programming tool to connect correctly to the device.
TINY PIC Bootloader
Support for the Serial TINY PIC Bootloader is documented here.
AVR
AVRISP mkII
$(compileravr)batchfiles\avrc.bat
Parameters:
AVRDUDE $(chipalt) $(chip:l) "$(outdir)$(target).hex" "$(target).hex" 0 $(cfgb) $(cfg0) $(cfg1) $(cfg2) $(cfg3)
USB Tiny
$(compileravr)batchfiles\avrc_usbtiny.bat
Parameters:
AVR Dude
The AVRDUDE programming tool supports a number of third party programmers for more help and information please visit the AVRDUDE home page.
AVRDUDESS is a graphical user interface for AVRdude.
Arduino
Flowcode Arduino allows you to specify a COM port to connect to the Arduino hardware via the Flowcode Project options window. Once you have specified the COM port and selected the correct target board the compile to chip option should program the Arduino device automatically using AVR dude.
Arduino Mega 2560 R1/R2
Flowcode is currently unable to program early versions of the Arduino Mega hardware. To program these devices use the tool Xloader to manually load the Flowcode generated .hex file onto the device.
ARM
Flowcode ARM comes with a set of precompiled bootloader files. This allows the matrix mLoader USB reprogrammable operation to be used on any third party ARM hardware.
mLoader
mLoader is the default programming software and can be used to talk to the various Matrix hardware including EB006, EB064, EB031, Formula Flowcode, ECIO, MIAC, ProtoBoard, ProjectBoard...
Parameters:
-eb0310 "$(target).s19"
SAM-BA
The SAM-BA tool is provided by Atmel and works with the default SAM7S bootloader which can be automatically restored to the device by powering up the ARM hardware for ten seconds using the TST jumper in the none default setting. Note this will delete the Matrix USB bootloader from the device.
ST ARM
ST-LINK
Flowcode by default is setup to use the ST-LINK programmer using the compile to chip option.
Discovery
Discovery boards are programmed by dropping the compiled binary firmware file onto a drive that appears under My Computer. Flowcode can automatically place the file onto the drive for you when using the compile to chip option with a discovery board selected as the target device.
Nucleo
Nucleo boards have a ST-LINK programmer built onto the board and so these work like standard ST ARM targets only without the additional requirement of a ST-LINK programmer.
Raspberry Pi
Raspberry Pi boards can be programmed over the network using Putty which is included with Flowcode. Enter the network details for the Pi into the Flowcode project options and this will allow the compile to chip to connect to the Pi using Putty via a SSH connection. SSH must be enabled on your Pi for this to function correctly but this should be enabled by default.
AISX Presto/Forte
First, make sure you have the latest UP installed on your computer. Make sure your path matches your installed location.
C:\Program Files (x86)\ASIX\UP\up.exe
Parameters:
/p /q "$(outdir)$(target).hex" /part PIC$(chip)
The way the command line works is by using the last UP.exe settings.
If you want to use the programmer’s internal supply.
Open UP.exe and within the programmer settings window, select During programming check box.
I would also recommend changing Delay for VDD switching on/off when supplied from programmer from 10000 to 50000.
Close UP then all is ready for programming.
If you want to see a popup progress bar during programming, remove /q from the parameters.
Note: Presto can only supply VDD 5.0V and VPP 13.0V Forte can supply VDD 2.0V to 5.5V and VPP 6.5V to 17 Automatically, depending on the selected target device.
If you are looking for additional command line programming the manual is available from here on page 63 at the time of writing
mikroProg
C:\Users\Public\Documents\Mikroelektronika\mikroProg Suite For PIC\mikroProg Suite For PIC.exe
Parameters:
-e -w -pPIC$(chip) -v -f"$(outdir)$(target).hex" -q
Note the -v is verify enabled. Verification will increase overall programming time. If you want to speed up programming then you can remove -v
