Component: GLCD Bitmap Drawer FAT (Graphical Library)
Revision as of 21:01, 23 December 2025 by Wiki bot (talk | contribs)
Version 3.0
Category Graphical Library
GLCD Bitmap Drawer FAT component
A component to simplify the process of drawing bitmap images to a graphical display. Reads Bitmap files directly from a SD card formatted with a FAT file system. Compatible with 24-bit & Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Compatible with GLCD, NeoPixel, MIACv3, HT16K33
Version information
20, 1.0, 26-07-24, BR, Added pallet buffer allowing 4,8-bit bitmaps to function
Here is an example that will scan for bitmap files in the root of the SD card and display them on a graphical display.
ZIP Icon.png Bitmap Drawer File Demo
The zip file contains the Flowcode project as well as some example bitmap image files taken from Pixabay.
Place the bitmap files on the root of the SD card for the embedded hardware to work.
Display_BMP
Fc9-comp-macro.png Display_BMP
Draws the bitmap image onto the display at the corrdinates X and Y. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
Bitmap file to open from current directory on SD card 8.3 format
Fc9-u16-icon.png - UINT X
X Axis coordinate, specifies the location of the left edge of the bitmap image
Fc9-u16-icon.png - UINT Y
Y Axis coordinate, specifies the location of the top edge of the bitmap image
0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
Fc9-u8-icon.png - BYTE Transparency
0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
Fc9-u8-icon.png - BYTE Flip
0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
Display_BMP_Fast
Fc9-comp-macro.png Display_BMP_Fast
Draws the bitmap image onto the display at the corrdinates X and Y. Speeds up drawing by not assigning X/Y coordinate for each pixel. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
Fc9-bool-icon.png - BOOL Mode
0=RowByRow, 1=FullWindow(Y Flipped)
Fc9-bool-icon.png - BOOL Orientation
0=Default, 1=Rotated 90 Degrees (only works with Mode 0)
Display_BMP_Fast_Partial
Fc9-comp-macro.png Display_BMP_Fast_Partial
Draws a partial bitmap image onto the display at the coordinates X and Y. Speeds up drawing by not assigning X/Y coordinate for each pixel. Allows drawing a percentage of the bitmap width and height from a specified side (top/bottom, left/right). Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
Fc9-u8-icon.png - BYTE WidthPercent
Percentage of bitmap width to draw. Range: 0-100
Fc9-u8-icon.png - BYTE HeightPercent
Percentage of bitmap height to draw. Range: 0-100
Fc9-u8-icon.png - BYTE HorizontalSide
Which horizontal side to draw from: 0=Left, 1=Right
Fc9-u8-icon.png - BYTE VerticalSide
Which vertical side to draw from: 0=Top, 1=Bottom
Display_BMP_Partial
Fc9-comp-macro.png Display_BMP_Partial
Draws a partial bitmap image onto the display at the coordinates X and Y. Allows drawing a percentage of the bitmap width and height from a specified side (top/bottom, left/right). Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
Display_Scaled_BMP
Fc9-comp-macro.png Display_Scaled_BMP
Draws the bitmap image onto the display at the corrdinates X and Y. Scales the bitmap to the specified width and height. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
Fc9-u16-icon.png - UINT Width
The size in pixels to draw the bitmap image
Fc9-u16-icon.png - UINT Height
Display_Scaled_BMP_Fast
Fc9-comp-macro.png Display_Scaled_BMP_Fast
Draws the bitmap image onto the display at the corrdinates X and Y. Scales the bitmap to the specified width and height. Speeds up drawing by not assigning X/Y coordinate for each pixel. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
GetHeight
Fc9-comp-macro.png GetHeight
Returns the height of the loaded bitmap file in pixels.
The filename of the bitmap we want to measure
GetWidth
Fc9-comp-macro.png GetWidth
Returns the width of the loaded bitmap file in pixels.
SetTransparentColour
Fc9-comp-macro.png SetTransparentColour
Sets the transparency colour, the colour that is not drawn when transparency is enabled.
Fc9-u8-icon.png - BYTE G
Fc9-u8-icon.png - BYTE B
Fc9-type-16-icon.png GLCD LinkTo
Fc9-type-16-icon.png File LinkTo
Fc9-type-7-icon.png ColourDisplay
Automatically detects if the graphical LCD object is colour or monochrome
Fc9-type-7-icon.png Pallet Buffer
Dedicates an area of RAM to be used as a pallet buffer allowing 4-bit and 8-bit bitmaps to be drawn efficiently. No: No additional RAM is used and only 1-bit and 24-bit bitmaps are supported. Yes: 768 additional bytes of RAM are used and 1-bit, 4-bit, 8-bit and 24-bit bitmaps are supported.
Fc9-type-7-icon.png Use File Index
Allows multiple files to be accessed at once.
Fc9-type-7-icon.png Use File Path
Allows a path to be specified for accessing bitmap files. e.g. Images\
Please click here to download the component source project: FC_Comp_Source_Lib_Draw_Bitmap_FAT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Lib_Draw_Bitmap_FAT.fcfx
