Component: RGB LED WS2811 / WS2812 / APA106 (LEDs)
Revision as of 21:16, 27 January 2026 by Wiki bot (talk | contribs)
Version 2.0
Category LEDs
RGB LED WS2811 / WS2812 / APA106 component
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Compatible with the WS2811, WS2812, WS2812B, APA104 and APA106 Type Controller ICs. Allows RGB LEDs to be driven with full 24-bit colour depth. Allows single chains, 2D arrays and 3D cube formations to be simulated. Requires a high speed microcontroller to generate the critical timings to drive the device.
Delay_T0H
Delay_T0H
Delay_T0L
Delay_T0L
Delay_T1H
Delay_T1H
Delay_T1L
Delay_T1L
DrawCuboid3D
DrawCuboid3D
Draws a basic 3D cuboid onto the LEDs
- BYTE X1
Start X pixel coordinate
- BYTE Y1
Start Y pixel coordinate
- BYTE Z1
Start Z pixel coordinate
- BYTE X2
End X pixel coordinate
- BYTE Y2
End Y pixel coordinate
- BYTE Z2
End Z pixel coordinate
- BYTE DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- BYTE R
Red Colour Channel
- BYTE G
Green Colour Channel
- BYTE B
White Colour Channel
DrawLine2D
DrawLine2D
Draws a line on a 2D array of LEDs
- UINT X1
Start X Coordinate
- UINT Y1
Start Y Coordinate
- UINT X2
End X Coordinate
- UINT Y2
End Y Coordinate
- BYTE R
Red colour channel
- BYTE G
Green colour channel
- BYTE B
Blue colour channel
DrawLine3D
DrawLine3D
Draws a line on a 3D array of LEDs
- UINT X1
Start X Coordinate
- UINT Y1
Start Y Coordinate
- UINT Z1
Start Z Coordinate
- UINT X2
End X Coordinate
- UINT Y2
End Y Coordinate
- UINT Z2
End Z Coordinate
- BYTE R
Red Colour Channel
- BYTE G
- BYTE B
Blue Colour Channel
DrawRectangle2D
DrawRectangle2D
Draws a basic 2D rectangle onto the LEDs
- BYTE X1
- BYTE Y1
- BYTE X2
- BYTE Y2
- BYTE DrawStyle
- BYTE R
- BYTE G
- BYTE B
GetLEDColour
GetLEDColour
Sets the colour of a single LED in RAM as a 1D array.
- UINT LED
LED to change the colour / Range: 0 to (LED Count - 1)
- BYTE ColIdx
0 = Red, 1 = Green, 2 = Blue
GetLEDIndex2D
GetLEDIndex2D
Sets the index of a single LED in RAM as a 2D array.
- UINT X
LED Column to change the colour / Range: 0 to (LED Column - 1)
- UINT Y
LED Row to change the colour / Range: 0 to (LED Row - 1)
GetLEDIndex3D
GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
- UINT X
- UINT Y
- UINT Z
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the LED ICs in the chain.
OutputHigh
OutputHigh
OutputLow
OutputLow
Refresh
Refresh
Clocks out the current colour data to the LEDs from the values stored in RAM
SetAllLEDColour
SetAllLEDColour
Sets the colour of all the LEDs in RAM
- BYTE R
Red Colour Channel
- BYTE G
- BYTE B
Blue Colour Channel
SetBrightness
SetBrightness
Allows the output colour brightness of the LEDs to be scaled down. For example to save current usage or to reduce brightness in dark environments.
- FLOAT Scaler
Range: 0.0 to 1.0 Default: 1.0, 0 = Off, 0.5 = Half Brightness, 1.0 = Full Brightness
SetBrightnessByte
SetBrightnessByte
- BYTE Scaler
Range: 0 to 255 Default: 255, 0 = Off, 128 = Half Brightness, 255 = Full Brightness
SetLEDColour
SetLEDColour
- UINT LED
- BYTE R
Red Colour Channel
- BYTE G
- BYTE B
Blue Colour Channel
ShiftLEDs1D
ShiftLEDs1D
Shifts the LED colours in 1D and wraps
- BYTE Direction
0 = Forwards, 1 = Backwards
- BYTE DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
ShiftLEDs2D
ShiftLEDs2D
Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
- INT X
Number of pixels to shift the display -1 to 1 / 0 = No Shift
- INT Y
- BYTE DataMode
ShiftLEDs3D
ShiftLEDs3D
- INT X
- INT Y
- INT Z
- BYTE DataMode
Controller IC
LED Controller
Allows the user to select which LED controller IC they are using. The different controller ICs all work the same way but have different timing characteristics.
Data Order
Configures the order the colour data is clocked out to the LEDs
Reset Time (uS)
Blanking reset period to reset the LED shift chain and start from the beginning
T0H (uS)
Logic 0 high time in microseconds
T0L (uS)
Logic 0 low time in microseconds
T1H (uS)
Logic 1 high time in microseconds
T1L (uS)
Logic 1 low time in microseconds
LED Properties
LED Arrangement
Controls the arrangement of the LEDs on the panel. 1D - Creates a straight line of LEDs 2D - Creates an X by Y Array of LEDs 3D - Creates an X by Y by Z Array of LEDs
LED Count
Total number of LEDs in the design
Column Spacing
X Spacing Between LEDs on the Panel
Data Pin
LED Data Pin - Connected to the Data In pin of the first WS821x IC.
Invert Data
Please click here to download the component source project: FC_Comp_Source_LED_WS2811.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_WS2811.fcfx
