Component: Digital Potentiometer (MCP45XX / MCP46XX) (Analog Output)
Revision as of 21:16, 27 January 2026 by Wiki bot (talk | contribs)
Category Analog Output
Digital Potentiometer (MCP45XX / MCP46XX) component
The MCP45XX and MCP46XX device range supports up to 2 digital potentiometers or rheostat outputs. 129 or 257 possible output resistance values for each channel.
Version information
6, 6.0, 11-11-24, MW, Added MC45HVX1 component
DecrementWiper
DecrementWiper
Decrements a single volatile wiper value
- BYTE Index
Range: 0-1
IncrementWiper
IncrementWiper
Increments a single volatile wiper value
- BYTE Index
Range: 0-1
Startup the I2C peripheral ready for communications.
ReadAddress
ReadAddress
Reads a value from one of the registers on the device
- BYTE Address
Range: 0-15
SetWiper
SetWiper
Sets the value of a single wiper
- BYTE Index
Range: 0-1
- UINT Value
129 Taps Range: 0-128 / 257 Taps Range: 0-256
- BOOL MemoryType
0=Volatile, 1=Nonvolatile
WriteAddress
WriteAddress
Writes a value to one of the registers on the device
- BYTE Address
Range: 0-15
- UINT Value
Range: 0-256
I2C Properties
Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Baud Select
Baud rate to be used
Stop Delay
Device Properties
Device
Number of Outputs
Number of Taps
Address Bits
Simulate Comms
Please click here to download the component source project: FC_Comp_Source_MCP45xx_46xx_Digital_Pot.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MCP45xx_46xx_Digital_Pot.fcfx
