Component: Switch Rotary 0 - 1 (Switch)
Revision as of 21:16, 27 January 2026 by Wiki bot (talk | contribs)
Version 6.0
Category Switch
Switch Rotary 0 - 1 component
A simple digital rotary switch allowing latched and none latched operation. In embedded mode displays the connecting pin and pin status.
Version information
6, 6.0, 23-09-24, MW, Fixed a bug that prevent pin status teext from changing to the correct GND or VCC
6, 6.0, 23-09-24, MW, Fixed a bug to  make sure switch starts in the off position
6, 6.0, 23-09-24, MW, Added option for simulation only
6, 6.0, 23-09-24, MW, Fixed a bug preventing custom lable posistion from updating on the fly
ReadState
ReadState
Reads the button state as 0 for released or 1 for pressed Performs debounce if required
SetState
SetState
Sets the switch to be on or off.
- BOOL State
The new state of the switch (true=on, false=off)
WaitUntilHigh
WaitUntilHigh
Waits until the switch is in state 'high' The interpretation of 'high' depends on the polarity
WaitUntilLow
WaitUntilLow
Waits until the switch is in state 'low' The interpretation of 'high' depends on the polarity
Function
Simulation Only
Switch Settings
Connection
The chip pin to which the switch connects.
Polarity
Set the polarity of states sent to the chip pin. 'Active High' -> Pressed = Set, Released = Clear 'Active Low' -> Pressed = Clear, Released = Set
Debounce
Sets the time in milliseconds to allow a pin change to settle into a stable state. NB) Debouncing is only used when reading the button state using the component macros. Chip pins are NOT debounced.
Latching
Determines if the simulated switch maintains its state or revers back to the default state when not clicked.
Component Label
Component label position
Label Colour
Show Connection Label
Show Pin Value
Pin label position
Set X Postion
Set Y Postion
Style
Type
On Label
Off Label
Please click here to download the component source project: FC_Comp_Source_Switch_Rotary_0_-_1_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Rotary_0_-_1_2dgi.fcfx
