Component: Power Board (BL0110) (E-blocks 2)
Revision as of 08:57, 27 April 2026 by Wiki bot (talk | contribs)
Category E-blocks 2
Power Board (BL0110) component
A component to drive the power board BL0110 either as a full bridge or as two half bridges.
SetDirection
Fc9-comp-macro.png SetDirection
Allows the direction of current to be reversed. Only applies to the Full Bridge mode.
Fc9-bool-icon.png - BOOL Direction
0=Forwards, 1=Reverse
SetDuty
Fc9-comp-macro.png SetDuty
0=A, 1=B
Fc9-u16-icon.png - UINT Duty
Range: 0 to Resolution - 1
StartPWM
Fc9-comp-macro.png StartPWM
StopPWM
Fc9-comp-macro.png StopPWM
Fc9-conn-icon.png Setup
Fc9-type-16-icon.png Mode
Defines how the driver is connected. A full bridge is capable of controlling a load like a DC motor offering speed and direction control. A half bridge is capable of controlling a load like a DC motor with speed control only.
Fc9-type-5-icon.png PWM A
Fc9-type-5-icon.png Enable A
Fc9-type-5-icon.png PWM B
Fc9-type-5-icon.png Enable B
Fc9-conn-icon.png Timer Properties
Fc9-type-16-icon.png Timer
Timer Peripheral to use to monitor the passage of time.
Fc9-type-21-icon.png Frequency (Hz)
Sets the control frequency of the PWM output. Recommend between 100 and 5000 Hz
Fc9-type-21-icon.png Resolution
Defines how many possible steps there are in the output PWM duty. Recommend 100 - 256 100 would allow for duty control values in the range of 0 (fully off) to 99 (fully on)
Fc9-type-21-icon.png Interrupt Rate (Hz)
The overall timer interrupt rate. Try to keep this as low as possible to avoid slowing down the system with excessive interrupts.
Please click here to download the component source project: FC_Comp_Source_EB_Power_BL0110.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EB_Power_BL0110.fcfx
