Component: GLCD (ST7789V) (Graphical Color)
Revision as of 08:57, 27 April 2026 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Color
GLCD (ST7789V) component
Graphical display component designed to work with the ST7789V 16-bit colour graphical controller IC.
Version information
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
BacklightOff
Fc9-comp-macro.png BacklightOff
Switches off the backlight
BacklightOn
Fc9-comp-macro.png BacklightOn
Switches on the backlight
ClearDisplay
DrawArc
Fc9-comp-macro.png DrawArc
Draws an arc either as an outline or as a filled object.
Center X coordinate
Center Y coordinate
Radius, distance of edge from the centre coordinates
Fc9-f32-icon.png - FLOAT StartAngle
Angle to start drawing, in degrees
Fc9-f32-icon.png - FLOAT EndAngle
Angle to end drawing, in degrees
Fc9-u16-icon.png - UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
Fc9-u8-icon.png - BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBezier
Fc9-comp-macro.png DrawBezier
Draws a quadratic Bezier curve with the current foreground colour from pixel location X0, Y0 to pixel location X2, Y2 using control point CX, CY.
Fc9-u16-icon.png - UINT X0
Start X coordinate
Fc9-u16-icon.png - UINT Y0
Start Y coordinate
Fc9-u16-icon.png - UINT CX
Control point X coordinate
Fc9-u16-icon.png - UINT CY
Control point Y coordinate
Fc9-u16-icon.png - UINT X2
End X coordinate
Fc9-u16-icon.png - UINT Y2
End Y coordinate
Number of segments to approximate the curve, 0 chooses an automatic value based on curve size.
DrawCircle
Fc9-comp-macro.png DrawCircle
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
DrawRectangle
Fc9-comp-macro.png DrawRoundedRectangle
Draws a rectangle with rounded corners
FastPlot
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
SetBackgroundColour
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
Window
Fc9-comp-macro.png Window
Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed.
Fc9-conn-icon.png Dimensions
Fc9-type-21-icon.png X Offset
Horizontal offset before the active display pixels.
Fc9-type-21-icon.png Y Offset
Vertical offset before the active display pixels.
Fc9-conn-icon.png Colour
Fc9-type-7-icon.png Invert Colours
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-7-icon.png Use SPI
No - Use dedicated IO pins to drive the display Yes - Use the micrcontroller's SPI peripheral to drive the display
Fc9-conn-icon.png SPI Settings
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-16-icon.png MOSI Remap Pin
Fc9-type-5-icon.png MISO
Fc9-type-16-icon.png MISO Remap Pin
Fc9-type-5-icon.png CLK
Fc9-type-16-icon.png CLK Remap Pin
Fc9-type-7-icon.png Queue Fast Pixels
An optimisation for ESP32 based devices where Fast pixels are queued up and all drawn together. Acts to speed up writes to the display when drawing lines, rectangles, ellipses, circles, none transparent strings etc.
Fc9-type-21-icon.png Pixel Queue Size
Defines how many fast pixels can be stored in the queue. The larger the number the more RAM used but the quicker the speed to write to the display. Each pixel = 2 bytes.
Fc9-type-7-icon.png Use CS
Fc9-type-7-icon.png Toggle CS
Selects if the chip select pin is automatically toggled or left selected. Yes - Slightly slower but allows pins to be multiplexed with other devices. No - Slightly faster.
Fc9-type-5-icon.png Chip Select
Chip select pin connection
Fc9-type-5-icon.png DC
Data/Command Pin
Fc9-type-7-icon.png Use Reset
Fc9-type-5-icon.png Reset
Reset Pin
Fc9-type-7-icon.png Use Backlight
Fc9-type-5-icon.png Backlight
Backlight Pin
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-type-21-icon.png Bytes Required
Number of bytes required in program memory to store the selected font.
Fc9-type-21-icon.png Character Spacing
Sets the number of blank pixels between each character when printing text.
Fc9-type-21-icon.png Space Width
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Physical Orientation
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
Please click here to download the component source project: FC_Comp_Source_GLCD_ST7789V.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7789V.fcfx
