Component: Switch Push Button (Switch)
Revision as of 08:58, 27 April 2026 by Wiki bot (talk | contribs)
Version 21.0
Category Switch
Switch Push Button component
A simple digital push switch allowing latched and none latched operation. In embedded mode displays the connecting pin and pin status.
Version information
15, 15.0, 30-07-24, MW, Fixed a bug to make sure switch starts in the off position
17, 17.0, 16-04-25, MW, Fixed a bug that made boundary height too large
17, 17.0, 16-04-25, MW, Fixed a bug where Pin x and  y lables remained visisble when supposed to be hidden
17, 17.0, 16-04-25, MW, Fixed a bug when sim stopped Switch changed from on to off, but pin remained at VCC
18, 18.0, 01-05-25, MW, Adjusted pin and component labels and bounds to decrease overall bounds size
18, 18.0, 01-05-25, MW, Changed labels so don't interact and change switch state
19, 19.0, 01-05-25, BR, Added option to hide label
19, 19.0, 01-05-25, BR, Fixed SameAsHandle label to update on rename event
20, 0.0, 14-05-25, MW, Changed Switch properties, so it does not grey out
21, 21.0, 10-03-26, ST, Updated for v11.0.1 mouse event change
Here is an example Flowcode program to read the value of a switch. FC6 Icon.png Switch
(5V / 11K) * 10K = 4.54545V
Note: if you want to use switch functions e.g. Active Low or debounce ,you must use the ReadState function and not use just an input.
ReadState
Fc9-comp-macro.png ReadState
Reads the button state as 0 for released or 1 for pressed Performs debounce if required
SetState
Fc9-comp-macro.png SetState
Sets the switch to be on or off.
Fc9-bool-icon.png - BOOL State
The new state of the switch (true=on, false=off)
WaitUntilHigh
Fc9-comp-macro.png WaitUntilHigh
Waits until the switch is in state 'high' The interpretation of 'high' depends on the polarity
WaitUntilLow
Fc9-comp-macro.png WaitUntilLow
Waits until the switch is in state 'low' The interpretation of 'high' depends on the polarity
Fc9-conn-icon.png Function
Fc9-type-7-icon.png Simulation Only
Fc9-conn-icon.png Switch Settings
Fc9-type-5-icon.png Connection
The chip pin to which the switch connects.
Fc9-type-16-icon.png Polarity
Set the polarity of states sent to the chip pin. 'Active High' -> Pressed = Set, Released = Clear 'Active Low' -> Pressed = Clear, Released = Set
Fc9-type-14-icon.png Debounce
Sets the time in milliseconds to allow a pin change to settle into a stable state. NB) Debouncing is only used when reading the button state using the component macros. Chip pins are NOT debounced.
Fc9-type-7-icon.png Latching
Determines if the simulated switch maintains its state or revers back to the default state when not clicked.
Fc9-conn-icon.png Label
Fc9-type-16-icon.png Component label position
Fc9-type-2-icon.png Label Colour
Fc9-type-7-icon.png Show Connection Label
Fc9-type-7-icon.png Show Pin Value
Fc9-type-16-icon.png Pin label position
Fc9-conn-icon.png Appearance
Fc9-type-16-icon.png Style
Fc9-type-12-icon.png Type
Fc9-type-10-icon.png On Label
Fc9-type-10-icon.png Off Label
Please click here to download the component source project: FC_Comp_Source_Switch_Push_Button_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Push_Button_2dgi.fcfx
