API Sound.QueueEx
Revision as of 15:34, 10 May 2013 by Admin (talk | contribs) (XML import API auto-gen)
wiki page name Queues a sound for playing, with the format provided
HANDLE Sounds
The handle of the sound object to queue to
BYTE[] Data
The array to play data from
ULONG ByteOffset
The byte-offset in the array to start at
UINT SampleFormat
Format of the samples
Typical values for this parameter:
ULONG Elements
The number of sample elements to play
FLOAT RateMul
A multiplier to the sounds sample rate
The default value for this parameter is: 1
BOOL
  • Add to a calculation icon: result = ::Sound.QueueEx(sounds, _arraydata, byteoffset, ::Sound.Fmt_Signed8, elements, ratemul)
