| Author
MatrixTSL
| Version
24.0
| Category
Graphical Library
Display Manager component
13, 2.0, 22-05-24, BR, Added text alignment options
14, 2.1, 14-06-24, BR, Renamed Button to Widget to better include things like sliders
15, 2.1, 26-07-24, BR, Added SetTextFloat and AddTextNumber macros
16, 2.1, 29-07-24, BR, Renamed Themes to ObjectThemes and WidgetThemes
17, 2.1, 29-07-24, BR, Added CreateTextField macro which automates creating a simple textbox
18, 2.1, 06-08-24, BR, Fixed a problem with updating values, theme, text on IDs
19, 2.1, 06-08-24, BR, Textfield now uses hidden object type instead of rectangle
20, 2.1, 06-08-24, BR, Fixed a problem where slider value could be set with out of range value
21, 2.1, 06-08-24, BR, Fixed problem where SetTextNumber would reset an ESP32
22, 22.0, 19-03-25, MW, Added keypad creation function
Objects
The component can create the following objects.
- Object_Hidden - 0 - A hidden area with no graphics.
- Object_Rectangle - 1 - A simple rectangular box.
- Object_Line - 2 - A simple straight line.
- Object_Ellipse - 3 - A simple ellipse or circle.
- Object_EllipseFilled - 4 - A filled ellipse or circle.
- Object_RectangeFilled - 5 - A filled rectangular box.
TextField
There is also an additional TextField object which consists of an Object_Rectangle that is pre-populated with text.
The component can also create the following interactive buttons and sliders.
- Widget_Hidden - 0 - A hidden area with no graphics.
- Widget_Rectangle - 1 - A rectangular box with a shadow.
- Widget_RoundedRectangle - 2 - A rounded rectangular box with a shadow.
- Widget_Ellipse - 3 - A simple ellipse or circle with a shadow.
- Widget_VSlider - 4 - A vertical slider with a square thumb.
- Widget_HSlider - 5 - A horizontal slider with a square thumb.
- Widget_VSlider_Round - 6 - A vertical slider with a round thumb.
- Widget_HSlider_Round - 7 - A horizontal slider with a round thumb.
The type can be entered by using the component's public constants. Begin with the Display Manager handle name followed by :: and the list of the public variables will be displayed.
For example... DisplayManager1::Object_Rectangle or DisplayManager1::Widget_VSlider
The Touch Repeat Rate property applies to button based widgets and sets the frequency that a valid touch will be detected for a held button. This is similar to holding down a single key on a keyboard and acts to reduce the frequency of positive button detections when touching the button. For example if you had a button that incremented a value, without the repeat rate the value would increment much faster then anticipated in an uncontrollable manner. When no touch is detected it is recommended to call the NoTouch macro to clear the touch counters and allow a more responsive user experience.
Example of implementing touch repeat rate
Flowcode v11
Video Tutorials
Graphical Display Manager and Layout Editor Part 1
Graphical Display Manager and Layout Editor Part 2
Converting Flowcode v10 examples
The v10 examples can also be used in v11 but the functions have changed slightly, now you need to define the colours for each object rather then by setting an overall colour theme.
To do this you must create a byte array with the correct number of bytes and then populate the byte array with the colours you wish to use. This can be done using a calculation icon.
Flowcode v10
Basic Example
An example showing how to use the display manager with a gLCD and a touch interface to create a full HMI.
Display Manager Demo
Keypad Example
An example showing how you can use the CreateWigitArray component to create a touch keypad for your gLCD.
The CreateWidgetArray function macro has a number of parameters to allow high flexibility in what you can create:
There are also tooltips for each parameter to help.
Note: if you get a unable to run simulation error then make sure you have the latest components downloaded.
How the key touch is detected
The first widget is automatically assigned a unique widget ID e.g. the first widget with text 1 on it is assigned 24.
All the following widgets ID is then incremented from 24, e.g. widget with text 6 on is assigned 24+ 5 = 29.
The widget button pressed can then be calculated from 29 – 24 + 1 = 6.
Display Manager Widget Array Keypad Example
CheckCollision
CheckCollision
| Checks to see if two objects bounding boxes are colliding, Useful when implementing 2D games.
- UINT
ID1
| ID of Object or Widget to check
- UINT
ID2
- BOOL
CheckForTouch
CheckForTouch
| Uses the X and Y coordinates from a touch sensor to check for Widget presses. Returns 0 for no Widgets pressed. Returns ID for a valid Widget press. Any touched slider Widgets will automatically move their thumb and value to the touch position.
- UINT
X
- UINT
Y
- UINT
ClearAll
ClearAll
| Removes all objects and Widgets from memory. Also clears the screen if required.
- BOOL
ClearScreen
| 0=Don't clear the screen, 1=Clear the screen
CreateObject
CreateObject
| Define a none touchable graphical object. Returns the Object ID.
- BYTE
ObjectType
| 0=Hidden, 1=Rect, 2=RoundedRect, 3=Ellipse, 4=Line, 8=Bitmap
- UINT
X
| X Pixel Coordinate
- UINT
Y
| Y Pixel Coordinate
- UINT
Width
| Pixel Width or X Radius
- UINT
Height
| Pixel Height or Y Radius
- BYTE
LineWidth
| Number of pixels thick to draw outer border lines
- BYTE
Colours
| Byte array containing FgColour RGB [0-2], Bg Colour RGB [3-5], Text Colour RGB [6-8]
- BOOL
DrawObject
| 0=Do not draw object yet, 1=Draw object now (Does not apply to hidden objects)
- UINT
CreateObjectArray
CreateObjectArray
| Creates a 2d array of objects that can be used to create things like table data. Returns the ID of the first object, the following objects have incremental IDs going column by column and then row by row.
- BYTE
ObjectType
- BYTE
NumColumns
| Number of columns of buttons in the array
- BYTE
NumRows
| Number of rows of buttons in the array
- UINT
InitialPositionX
| X location of the initial button
- UINT
InitialPositionY
| Y location of the initial button
- UINT
ObjectWidth
| Widget width in pixels
- UINT
ObjectHeight
| Object height in pixels
- UINT
SpacingX
| Horizontal spacing between the objects
- UINT
SpacingY
| Vertical spacing between the objects
- BYTE
LineWidth
- BYTE
Colours
- BYTE
Font
| Font used for the widgets text
- STRING
ObjectText
| A comma seperated text field with the text for each object e.g. "1,2,3,.."
- UINT
CreateTextField
CreateTextField
| Creates a text field consisting of a rectangular border containing a single line of text
- STRING
Text
| Text string to set as the label
- UINT
X
| X Pixel Coordinate
- UINT
Y
| Y Pixel Coordinate
- UINT
Width
| Pixel Width
- UINT
Height
| Pixel Height
- BYTE
Font
| GLCD Font Index to use
- BYTE
Colours
- BYTE
HAlignment
| 0=Left, 1=Center, 2=Right
- BYTE
VAlignment
| 0=Top, 1=Middle, 2=Bottom
- UINT
CreateWidget
| Define an interactive Widget or slider. Returns the Widget ID.
- BYTE
WidgetType
| 0=WidgetHidden, 1=WidgetRect, 2=WidgetRoundedRect, 3=WidgetEllipse, 4=VSlider, 5=HSlider, 6=VSliderRound, 7=HSliderRound, 8=Bitmap
- UINT
X
| X Pixel Coordinate
- UINT
Y
| Y Pixel Coordinate
- UINT
Width
- UINT
Height
- BYTE
LineWidth
- BYTE
Colours
| Byte array containing FgColour RGB [0-2], Bg Colour RGB [3-5], Text Colour RGB [6-8], Hl Colour RGB [9-11]
- BYTE
DrawHighlight
| Draws the highlight on buttons, also used for thumb width on sliders
- BOOL
DrawWidget
| 0=Do not draw Widget yet, 1=Draw Widget now (Does not apply to hidden widgets)
- UINT
CreateWidgetArray
| Creates a 2d array of buttons that can be used to create things like keypads. Returns the ID of the first button, the following buttons have incremental IDs going column by column and then row by row.
- BYTE
WidgetType
- BYTE
NumColumns
- BYTE
NumRows
- UINT
InitialPositionX
- UINT
InitialPositionY
- UINT
WidgetWidth
- UINT
WidgetHeight
| Widget height in pixels
- UINT
SpacingX
| Horizontal spacing between the widgets
- UINT
SpacingY
| Vertical spacing between the widgets
- BYTE
LineWidth
- BYTE
Colours
- BYTE
Font
- STRING
WidgetText
| A comma seperated text field with the text for each widget e.g. "1,2,3,.."
- BYTE
DrawHighlight
- UINT
DrawAll
DrawAll
| Redraws all of the defined Objects and Widgets. Doesn't draw text, this is done using the SetText macros.
DrawItem
DrawItem
| Draws a single object or Widget onto the display without clearing the display. Doesn't draw text, this is done using the SetText macros.
- UINT
ID
| Unique ID of the Object or Widget
DrawScene
DrawScene
| Clears the screen and adds and draws the objects and widgets from the layout editor.
- BYTE
SceneIndex
| Select which screen to draw. Range: 0 to Scene Count - 1
GetLastTouchID
GetLastTouchID
| Gets the ID of the last Widget that returned a valid press via the CheckForTouch macro. Returns 0 for no valid touch recorded.
- INT
GetSceneIdx
GetSceneIdx
| Gets the index of the current drawn scene allowing for variable behaviour based on the scene.
- BYTE
GetSliderValue
GetSliderValue
| Reads the value of one of the sliders ranging between 0 and 1.
- UINT
WidgetID
- FLOAT
| Initialises the object and Widget control variables and sets up the default themes.
ModifyBitmap
ModifyBitmap
| Allows the bitmap image to be swapped out
- UINT
ID
| Object or Widget ID to update
- STRING
Filename
| Bitmap filename in 8.3 file format
- BOOL
Scaling
| 0=Native, 1=Stretch
- BOOL
Transparancy
| 0=Disabled, 1=Enabled
- BOOL
Redraw
ModifyColour
ModifyColour
| Changes the theme index of the selected Object or Widget.
- UINT
ID
| Unique ID of the object or Widget
- BYTE
Index
| 0=Foreground, 1=Background, 2=TextColour, 3=Highlight(Widgets Only)
- BYTE
R
| Colour Channels
- BYTE
G
| Colour Channels
- BYTE
B
| Colour Channels
- BOOL
Redraw
| Redraws the component straight away in the new colours
ModifyPosition
ModifyPosition
| Moves an existing object or Widget to absolute coordinates on the screen.
- UINT
ID
- INT
X
- INT
Y
- BOOL
Relative
| 0=Absolute Positioning, 1=Relative Positioning
ModifyScale
ModifyScale
| Changes the width and height of the selected Object or Widget.
- UINT
ID
- UINT
Width
- UINT
Height
NoTouch
NoTouch
| Called when no touch is present, Allows the repeat rate counter to be cleared allowing for better responses to fast touches.
SetSliderValue
SetSliderValue
| Sets the value of one of the sliders and optionally redraws the slider to reflect the value change.
- UINT
WidgetID
- FLOAT
Value
| Range: 0 to 1
- BOOL
RedrawSlider
| 0=Do not redraw, 1=Redraw
SetTextLabel
SetTextLabel
| Draws a single line of text onto an object or Widget location. Useful for labelling Widgets such as buttons or having name, value statistics. Drawn using the object themes.
- UINT
ID
| Unique identifier of object or Widget.
- STRING
Text
- BYTE
Font
- BYTE
HAlignment
- BYTE
VAlignment
- BOOL
Transparent
| 0=Background Colour Drawn, 1=Don't Draw Background Colour
Graphical Display
| Graphical Display to draw our objects on
DM Library
| Display Manager compatible GLCD library component. e.g. Bitmap drawer components.
Ram Usage Bytes
| The calculated number of bytes of RAM required by the display manager.
Text Align Offset
| Number of pixels to move away from an edge when calling
Background Colour
| Default background colour to use when clearing the display and applied as the default when creating new display creator scenes.
Objects
Max Objects
| The total number of primitive objects allowed on the screen at once. Sets the size of the RAM buffers used to track the various screen elements. Each object requires 10 bytes of RAM to stores things like size, location and type.
Widgets
Max Widgets
| The total number of touchable interactibe objects allowed on the screen at once e.g. Widgets and sliders. Sets the size of the RAM buffers used to track the various screen elements Each Widget requires 18 bytes of RAM to stores things like size, location, value and type.
Touch Repeat Rate
| Sets the period for touch repeats in terms of calls of the CheckForTouch macro. Widgets will only register a repeat touch after x calls if continually held down. Sliders will always register a touch. The touch count can be cleared using the NoTouch macro if no touch is detected.
Display Creator
Enabled
| Enable the display creator (WYSIWYG) scene panels.
Settings
Enable Callbacks
| Allows the widgets to define their own callback macros to simplify the act of processing touches
Scene Count
| Defines the number of invididual scene layout, display creator scenes available to draw
Scene Data
Scene 0
