| Author
Matrix TSL
| Version
1.0
| Category
Wireless
Zigbee (ESP32-C6/H2) component
Zigbee component project for ESP32-C6 and ESP32-H2 devices.
BytesAvailable
BytesAvailable
| Returns number of bytes waiting in RX buffer. Applicable to: Coordinator, Router, End Device.
- UINT
GetChannel
GetChannel
| Returns currently active Zigbee channel. Applicable to: Coordinator, Router, End Device.
- BYTE
GetPANID
GetPANID
| Returns current PAN ID. Applicable to: Coordinator, Router, End Device.
- UINT
GetShortAddress
GetShortAddress
| Returns this node short network address. Applicable to: Coordinator, Router, End Device.
- UINT
InitNetwork
InitNetwork
| Initialises Zigbee stack, applies default routing from properties, and optionally starts commissioning. Applicable to: Coordinator, Router, End Device. Call once at startup before send/receive macros.
IsJoined
IsJoined
| Returns 1 when node is joined/formed onto a Zigbee network, else 0. Applicable to: Coordinator, Router, End Device.
- BYTE
IsNetworkReady
IsNetworkReady
| Returns 1 when Zigbee stack/network is ready for data transfer, else 0. Applicable to: Coordinator, Router, End Device.
- BYTE
ReceiveArray
ReceiveArray
| Reads available data into an array buffer. Applicable to: Coordinator, Router, End Device. Returns number of bytes copied.
- STRING
Buffer
| Output byte array.
- UINT
MaxLen
| Maximum bytes to copy into Buffer.
- UINT
ReceiveByte
ReceiveByte
| Reads one byte from RX buffer. Applicable to: Coordinator, Router, End Device. Returns 0-255 for data, or 256 when no data is available.
- UINT
ReceiveString
ReceiveString
| Reads available data and returns a null-terminated string. Applicable to: Coordinator, Router, End Device. Returns number of data bytes copied (excluding terminator).
- STRING
Buffer
| Output string buffer.
- UINT
MaxLen
| Buffer length including null terminator.
- UINT
SendArray
SendArray
| Sends an array of bytes through Zigbee transport. Applicable to: Coordinator, Router, End Device. Uses current TX mode/address/endpoint/cluster settings.
- STRING
Data
| Array containing bytes to send.
- UINT
Length
| Number of bytes to send from Data.
- UINT
SendByte
SendByte
| Sends one byte using current TX routing settings. Applicable to: Coordinator, Router, End Device.
- BYTE
Data
| Byte to send.
- BYTE
SetPermitJoin
SetPermitJoin
| Opens join window for a number of seconds. Primary use: Coordinator (and Router if your network design allows it). Not usually meaningful for End Device.
- BYTE
Seconds
| Permit join timeout in seconds. 0 closes joining.
SetRXRouting
SetRXRouting
| Dynamically updates RX endpoint/cluster filters at runtime. Applicable to: Coordinator, Router, End Device.
- BYTE
Endpoint
| Accepted receive endpoint.
- UINT
Cluster
| Accepted receive cluster.
SetTXRouting
SetTXRouting
| Dynamically updates TX mode/address/endpoint/cluster at runtime. Applicable to: Coordinator, Router, End Device.
- BYTE
Mode
| 0 unicast, 1 groupcast, 2 broadcast.
- UINT
ShortAddress
| Destination short/group address.
- BYTE
Endpoint
| Destination endpoint.
- UINT
Cluster
| Destination cluster.
SetZigbeeRole
SetZigbeeRole
| Dynamically changes runtime Zigbee role. Use for fallback logic (for example Router then Coordinator). If ApplyNow=1, role config is applied immediately and commissioning is started.
- BYTE
Role
| 0 coordinator, 1 router, 2 end device.
- BOOL
ApplyNow
| If true, immediately applies config and starts commissioning.
StartCommissioning
StartCommissioning
| Starts commissioning based on current runtime role. Coordinator: starts network formation. Router/End Device: starts network steering (join). Call after InitNetwork if Auto Start is disabled.
TaskPoll
TaskPoll
| Runs Zigbee stack polling. Applicable to: Coordinator, Router, End Device. Call regularly in your main loop (or timer) so Zigbee events are processed.
- ULONG
TimerID
| System timer identifier
- ULONG
zigbee_config
zigbee_config
| Low-level runtime Zigbee role/endpoint/channel config. Applicable to: all roles. Usually called by InitNetwork and SetZigbeeRole.
- BYTE
role
- BYTE
endpoint
- ULONG
channel_mask
zigbee_init
zigbee_init
| Low-level Zigbee stack initialise call. Applicable to: all roles. Usually called by InitNetwork.
zigbee_transfer_config_rx
| Low-level internal config for TX destination and RX filters. Applicable to: Coordinator, Router, End Device. Usually called by InitNetwork / SetTXRouting / SetRXRouting.
- BYTE
rx_endpoint
| Accepted incoming endpoint.
- UINT
rx_cluster
| Accepted incoming cluster id.
zigbee_transfer_config_tx
| Low-level internal config for TX destination. Applicable to: Coordinator, Router, End Device. Usually called by InitNetwork / SetTXRouting / SetRXRouting.
- BYTE
tx_mode
- UINT
tx_short_addr
| Destination short address (or group id for groupcast).
- BYTE
tx_endpoint
- UINT
tx_cluster
| Destination cluster id.
Zigbee Role
| Select how this node behaves on the network. Coordinator: creates and manages the network. Router: joins a network and can forward traffic. End Device: joins a network as a leaf node. Suggested start: Router for joining existing networks, Coordinator if creating a new network.
Endpoint
| Local application endpoint for this component. Think of this as the local app port number. Suggested value: 10 (keep all nodes consistent unless you need multiple logical apps).
Auto Start Commissioning
| If enabled, InitNetwork will immediately start commissioning. Enable for simple projects. Disable if you want manual control via StartCommissioning macro.
Default Routing
TX Address Mode
| How outgoing data is addressed. Unicast: send to one node. Groupcast: send to nodes in a group. Broadcast: send widely. Suggested start: Unicast.
TX Short Address
| Destination short address (or group id if using Groupcast), in decimal. For Coordinator, this is often 0. Suggested start for unicast testing: 0 (coordinator) or the target node short address.
TX Endpoint
| Destination endpoint on the remote node. Must match the receiver app endpoint. Suggested value: 10.
TX Cluster
| Destination cluster id in decimal. Both sender and receiver should use the same cluster. Suggested custom cluster: 64512 (0xFC00).
RX Endpoint
| Only payloads for this endpoint are accepted into the RX buffer. Suggested value: 10 (match your local endpoint).
RX Cluster
| Only payloads for this cluster are accepted into the RX buffer. Suggested value: 64512 (0xFC00), matching TX cluster.
Channels
Channel Mask (Auto)
| Read-only channel mask calculated from the channel checkboxes. You do not need to edit this directly. Common full-range value (11-26 enabled): 134215680.
Channel 11
| Enable channel 11. Suggested: leave enabled unless avoiding local interference.
Channel 12
| Enable channel 12. Suggested: leave enabled for general discovery.
Channel 13
| Enable channel 13. Suggested: leave enabled for general discovery.
Channel 14
| Enable channel 14. Suggested: leave enabled for general discovery.
Channel 15
| Enable channel 15. Suggested: leave enabled for general discovery.
Channel 16
| Enable channel 16. Suggested: leave enabled for general discovery.
Channel 17
| Enable channel 17. Suggested: leave enabled for general discovery.
Channel 18
| Enable channel 18. Suggested: leave enabled for general discovery.
Channel 19
| Enable channel 19. Suggested: leave enabled for general discovery.
Channel 20
| Enable channel 20. Suggested: leave enabled for general discovery.
Channel 21
| Enable channel 21. Suggested: leave enabled for general discovery.
Channel 22
| Enable channel 22. Suggested: leave enabled for general discovery.
Channel 23
| Enable channel 23. Suggested: leave enabled for general discovery.
Channel 24
| Enable channel 24. Suggested: leave enabled for general discovery.
Channel 25
| Enable channel 25. Suggested: leave enabled for general discovery.
Channel 26
| Enable channel 26. Suggested: leave enabled for general discovery.
Please click here to download the component source project: FC_Comp_Source_Zigbee_ESP32.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Zigbee_ESP32.fcfx
