API Component.Property.SetFilter
Revision as of 14:08, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;" align="center"" to "width="10%" align="center" class="mtx-class-macrohead"")
SetFilter
Sets a components property filter string for lists, files, etc
- HANDLE Handle
The component handle of the property owner
- STRING Property
The textual name of the property
- STRING Value
The value to update the property filter with
- NONE Return
Sets the filter field of a property. The filter field is a text block whose use in Flowcode is decided by the properties type.
The field, for example, may be used to hold a list of items in a list-type property, or a file-filter in a file selection property. See the list of property types for further details.
No checks are done for validation on the field, and any text desired may be entered into this. However, it is the callers responsibility to only add text with the correct format if a format is required..
  • Add to a calculation icon:
    ::Component.Property.SetFilter(handle, "property", "value")
