Event DataRecorder.Decode
Revision as of 14:13, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;" align="center"" to "width="10%" align="center" class="mtx-class-macrohead"")
Decode
Sent when a block of the stream is to be decoded into packets
- HANDLE StreamH
The stream handle
- LONG TimeOffset
The -ve offset from now of the earliest time to be decoded
- ULONG Duration
The maximum number of ticks to decode into packets packet from the TimeOffset
- ULONG Return
Non-zero if the data could be decoded
Details on using Event Macros can be found here: Event Macros
