Component: Grey Code Encoder (General Input)
Version 1.4
Category General Input
Grey Code Encoder component
Grey Code Encoder component implements a rotary encoder connected to a defined number of pins Grey Code Encoders provide absolute positioning rather than incremental positioning.
Please click here to download the component source project: FC_Comp_Source_Encoder_Grey_Code.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Encoder_Grey_Code.fcfx
ReadAbsoluteAngle
ReadAbsoluteAngle
Reads the absolute angular position of the motor. Returns a floating point value representing the angle of the encoder.
- FLOAT Return
ReadAbsolutePosition
Reads the absolute angular position of the motor. Returns an integer value representing the step position.
Rotate
Rotate
Simulation Rotate function to allow accurate rotation during simulation. Automatically called by any attached coupling or gearbox component.
- FLOAT Angle
Amount to rotate the shaft input in degrees
Encoder Resolution
Output States
Number of unique output states
Resolution
The resolution of the encoder in degrees
Number of Pins
Sets the number of output pins on the encoder and hence the resolution of the encoder.
Pin0
Input pin 0
Pin1
Input Pin 1
Pin2
Input Pin 2
Repeat Rate
Simulated repeat rate when clicking and rotating the encoder
