Component: Bluetooth (EB024, Generic AT) (Wireless)
Revision as of 14:16, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;" align="center"" to "width="10%" align="center" class="mtx-class-macrohead"")
Author Matrix Ltd.
Version 2.0
Category Wireless
Bluetooth (EB024, Generic AT) component
Low level routines for controlling a standard AT Bluetooth interface. Also available in the form of the EB024 Bluetooth E-block.
Please click here to download the component source project: FC_Comp_Source_Bluetooth.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Bluetooth.fcfx
Making a device discoverable
Example program to set up the Bluetooth module to be discoverable with a pair key. Any data received is then output onto the LCD component. You can connect to the Bluetooth device using a PC with Bluetooth connection and using software such as Flowcode 6, RealTerm or HyperTerminal. Alternatively you can connect using a smart phone running a terminal emulator app or via another embedded Bluetooth board. Bluetooth Discover Script 1 contains the AT commands to setup the Bluetooth device to be discoverable with pair key "1234".
Searching for a device
Example program to scan for local discoverable Bluetooth devices. For each device found the MAC address is displayed on to the LCD. Bluetooth Inquiry
Connecting to a device
Example program to connect to a specific Bluetooth device address and send data to the device. Bluetooth Connect The device MAC address is specified using the "CreateCommandString" and "SendCommand" macros.
CreateCommand
CreateCommand
Adds a single characters to the end of the Command buffer. Returns 1 for success in adding the characters to the buffer. Returns 0 for errors, including Buffer overflow.
- BYTE Character
ASCII value or single character,
CreateCommandString
CreateCommandString
Assigns a string of characters to the Command buffer. Returns 1 for success in adding the characters to the buffer. Returns 0 for errors, including Buffer overflow.
- STRING Data
Required to be used whenever the Bluetooth component is used in a program. Initialises the Bluetooth component ready for use.
SendCommand
SendCommand
Sends the command buffer. Returns 1 for success in sending the command. Returns 0 for errors.
- BYTE ExpectEcho
Remote module automatically echos back data: 1 = On (Expect echo), 0 = off
- BYTE SendCR
Automatically adds \n to the end of the command data: 1 = append CR, 0 = no CR.
SendScript
SendScript
Sends Script idx Note that the general property Number of Scripts needs to be set so that it allows the scripts to be accessed and sent. Returns 0 for success and 1 for error
- BYTE idx
Refers to the Script page to send (1-4).
Send_byte
Send_byte
- BYTE ByteVal
StringRead
StringRead
Returns the ASCII value of character idx of the Response string.
- BYTE idx
Needs to be a equal to or less than the string length of the response in order to retrieve a valid character.
StringReceive
StringReceive
Checks for a response string. Returns the length of the response string if one is present otherwise returns 0.
WaitForResponse
WaitForResponse
Waits for a response message of type response_code for timeout ms. Returns: 0 for a Response of type response_code 255 (0xFF) for a timeout or invalid response Response string length for any Response not of type response_code
- BYTE response_code
1:OK / 2:ERROR / 3:CONNECT / 4:NO CARRIER / 5:AUDIO / 6:PAIR / 7:RING
- BYTE timeout
The timeout value will need to set to allow sufficient time for the response to arrive.
Command Buffer Size
Maximum number of bytes that can be stored in the outgoing command buffer.
Response Buffer Size
Maximum number of bytes that can be stored in the incoming response buffer.
Script Count
Controls how many AT scripts are stored into non-volatile memory
Script 1
Data to send for script 0, each command should be terminated with a carriage return
TX
RX
Use Flow Control
Baud Options
Console Columns
Data Source
API
Selects whichAPI component to route the communication data via. Add API components to the panel before they will be available in this list. API components are available from the Comms component category.
