Component: Gyroscope 3-Axis SPI (L3GD20) (Movement Orientation)
Version 2.0
Category Movement Orientation
Gyroscope 3-Axis SPI (L3GD20) component
Allows access to a three axis digital gyroscope via an SPI interface. Useful for gaming, VR, motion control, navitagion and robotics.
Please click here to download the component source project: FC_Comp_Source_Gyroscope_L3GD20_SPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Gyroscope_L3GD20_SPI.fcfx
GetGyroReading
GetGyroReading
Collects one of the gyroscope readings from the last sample.
- BYTE Axis
0=X, 1=Y, 2=Z
- INT Return
Initialises the SPI bus ready to communicate with the sensor.
ReadRegister
ReadRegister
Reads a single register from the gyroscope and returns the value as a byte.
- BYTE Address
SampleDevice
SampleDevice
Collects the gyro readings from the device.
WriteRegister
WriteRegister
Writes a single register on the gyroscope.
- BYTE Address
- BYTE Data
Sensor Configuration
Output Data Rate
Specifies the gryoscope sample data rate
Full Scale Selection
Specifies the maximum angular speed which the sensor can measure in degrees per second
Bandwidth Selection
Linked with data rate, See device datasheet table 21.
Filter Enable
Enables automatic internal filtering on the gyro data
X Axis
Enables or disables the selected axis allowing it to generate data or be switched off to save power.
Y Axis
Z Axis
SPI Connection
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Simulation Type
