Component: API (ECIO40P) (API Slave Devices)
Version 4.0
Category API Slave Devices
API (ECIO40P) component
Connects to an ECIO40P running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_ECIO40P_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ECIO40P_API_Comp.fcfx
The App Developer (ECIO40P) component allows an ECIO40P board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the ECIO40P hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
ECIO40P App Developer Firmware
The COM port to the ECIO hardware is selected via the SCADA_ECIO40P component COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
  • fixed statistics showing IO / ADC inputs / PWM
  • scrolling log showing all commands and returns
Pin Mapping
App Developer Slave Digital Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
Device Port Pin A0 A1 A2 A3 A4 A5 B0 B1 B2 B3 B4 B5 B6 B7 C0 C1 C2 C6 C7 D0 D1 D2 D3 D4 D5 D6 D7 E0 E1 E2
App Developer Slave Analogue Pin 0 1 2 3 4 5 6 7 8 9 10 11 12
Device Port Pin A0 A1 A2 A3 A5 E0 E1 E2 B2 B3 B1 B4 B0
App Developer Slave Peripheral Pin I2C SDA I2C SCL SPI MOSI SPI MISO SPI SCK UART RX UART TX PWM 0 PWM 1
Device Port Pin B0 B1 C7 B0 B1 C7 C6 C2 C1
Direct Slave Access
Here is a simple demo to switch on and off digital pin 29 (the LED pin).
ECIO40P App Developer Example
ADCSample10
ADCSample10
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023
- BYTE ADCChannel
Range: 0-12
ADCSample8
ADCSample8
Reads the voltage present on an Alanog pin as an 8-bit value range 0-255
- BYTE ADCChannel
Range: 0-12
ADCSampleArray10
ADCSampleArray10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleArray8
ADCSampleArray8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- BYTE Samples
8-bit samples returned from the function
ADCSampleAverage10
ADCSampleAverage10
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
ADCSampleAverage8
ADCSampleAverage8
- BYTE ADCChannel
Range: 0-5
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
ADCSetPrechargeTime
ADCSetPrechargeTime
Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
- BYTE ChargeTime
Default 10
ADCSetReferenceVoltage
Specified the reference setting for ADC reads.
- BYTE RefType
0=VDD 1= VREF+ (AN3)
I2CInitialise
I2CInitialise
- BYTE Channel
- BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
I2CReceive
I2CReceive
- BYTE Channel
- BOOL Last
I2CRestart
I2CRestart
- BYTE Channel
I2CSend
I2CSend
- BYTE Channel
- BYTE DataOut
- BOOL Return
I2CStart
I2CStart
- BYTE Channel
I2CStop
I2CStop
- BYTE Channel
I2CTransInit
I2CTransInit
- BYTE Channel
- BYTE DeviceAddress
7-bit Device Address
- BYTE Baud
I2CTransReceive
I2CTransReceive
- BYTE Channel
- BYTE Data
Data variable to receive into
- UINT Count
Number of bytes to receive
I2CTransSend
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
IOGetInputPin
IOGetInputPin
- BYTE Pin
Range: 0-29
- BOOL Return
IOSetOutputPin
IOSetOutputPin
- BYTE Pin
Range: 0-29
- BOOL State
Range: 0-1
Initialise the comms to the ECIO40P device, ready for commands to be sent.
PWMDisable
PWMDisable
Disable a PWM output
- BYTE Channel
Range: 0-1
PWMEnable
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-1
PWMSetDuty
PWMSetDuty
- BYTE Channel
Range: 0-1
- BYTE Duty
PWMSetPrescaler
PWMSetPrescaler
- BYTE Channel
- BYTE Prescaler
- BYTE Period
RegisterRead
RegisterRead
Read one of the registers on-board the device
- UINT RegisterAddress
The address of the register
RegisterWrite
RegisterWrite
Writes to one of the registers on-board the device
- BYTE Data
The data value to assign to the register
SPIInitialise
SPIInitialise
- BYTE Channel
SPIPrescaler
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
SPITransfer
SPITransfer
- BYTE Channel
- BYTE DataOut
SPITransferTrans
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
UARTBaud
UARTBaud
- BYTE Channel
- BYTE Rate
UARTCheckRX
UARTCheckRX
- BYTE Channel
UARTInitialise
UARTInitialise
- BYTE Channel
UARTReceive
UARTReceive
- BYTE Channel
UARTSend
UARTSend
- BYTE Channel
- BYTE Data
Connection
Auto Detect
COM Port
Lists all the current available COM port hardware on your PC.
Refresh Ports
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
SERVO
Console
Console Log
Create an automatic console log of the commands sent to the Arduino
Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns ASCII mode allows serial data to be shown in raw text form, other commands are shown as in the Command Log mode
