Component: Colour GLCD (BL0157) (E-blocks 2)
Version 9.9
Category E-blocks 2
Colour GLCD (BL0157) component
Graphical display component designed to work with the BL0157 E-block. Based on the ILI9163C 16-bit colour graphical controller IC.
A simple example that shows how to use some common functions.
Now can take advantage of SPI faster speed, instead of bit banging
BL0157 Example
BL0157 Maze Builder
Maze Builder gLCD
Example to draw a randomly generated 2D maze on an BL0157 graphical display.
BL0157 Drawing 3D Objects With Perspective
3D Manipulations
BPlot
BPlot
- UINT X1
- UINT Y1
BacklightOff
BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BacklightOn
BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
ClearDisplay
ClearDisplay
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT X
Center X coordinate
- UINT Y
Center Y coordinate
- UINT Radius
Radius, distance of edge from the centre coordinates
- FLOAT StartAngle
Angle to start drawing, in degrees
- FLOAT EndAngle
Angle to end drawing, in degrees
- UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
DrawRoundedRectangle
Draws a rectangle with rounded corners
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- UINT Radius
- BYTE Transparent
- BYTE Solid
FastPlot
FastPlot
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetBackgroundColour
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
Window
Window
Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed.
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Use SPI
Data
Data pin connection
Clock
Clock pin connection
Chip Select
Chip select pin connection
A0
Reset
Reset pin connection
LED
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Component Label
Component Label Scale
Physical Orientation
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Colour_GLCD_BL0157.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Colour_GLCD_BL0157.fcfx
