Component: Gyroscope 3-Axis (L3G4200D) (Movement Orientation)
Version 2.0
Category Movement Orientation
Gyroscope 3-Axis (L3G4200D) component
Interface to the L3G4200D three axis digital gyroscope. Panel GUI can be used to simulate incoming data for testing.
Please click here to download the component source project: FC_Comp_Source_Gyroscope_L3G4200D.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Gyroscope_L3G4200D.fcfx
GetX
GetX
Returns the previously sampled X axis data
- INT Return
GetY
GetY
Returns the previously sampled Y axis data
- INT Return
GetZ
GetZ
Returns the previously sampled Z axis data
- INT Return
Initialise the component.
ReadRegister
ReadRegister
Read the data byte at the given address of the device
- BYTE Reg
address of the register to be read
SampleDevice
SampleDevice
Reads the Axis data from the device
WriteRegister
WriteRegister
Writes the data byte to the given address of the device. Returns 0 if successful
- BYTE Reg
address of register to be written with data byte
- BYTE Data
data byte to be written to device register
Output Data Rate
Full Scale Selection
Specifies the maximum angular speed which the sensor can measure in degrees per second
X Axis
Y Axis
Z Axis
Connection
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Simulate Comms
