Component: TTI TG5011 Signal Generator (TG5011) (Test Equipment)
Version 0.2
Category Test Equipment
TTI TG5011 Signal Generator component
TTi TG5011 50 MHz Signal Generator
Please click here to download the component source project: FC_Comp_Source_TTITG5011.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_TTITG5011.fcsx
ADDRESSRet
ADDRESSRet
Returns the instruments address
- INT Return
AMPL
AMPL
Sets the amplitde to <nrf> in the units as specified by the AMPUNIT command. (Range = 10mVpp - 10Vpp)
- FLOAT Amplitude
Sets the amplitude (10mVpp - 10Vpp). Units specificied by AMPUNIT command.
AMPLRNG
AMPLRNG
Sets the amplitude range to; 0 = AUTO, 1 = HOLD.
- BOOL Range
Sets the amplitude range (0 = AUTO, 1 = HOLD).
AMPUNIT
AMPUNIT
Sets the amplitude units to; 0 = VPP, 1 = VRMS, 2 = DBM.
- BYTE Units
Sets the amplitude units (0 = VPP, 1 = VRMS, 2 = DBM).
ARB1
ARB1
Loads the binary-data to an existing arbitrary waveform memory location ARB1.
- UINT Waveform
16 Bit binary number for arbitrary waveform.
ARB1DEFRet
ARB1DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB1.
- STRING Return
ARB1Ret
ARB1Ret
Returns the binary-data from an existing abbitrary wavefrom memory location.
ARB2
ARB2
Loads the binary-data to an existing arbitrary waveform memory location ARB2.
- UINT Waveform
ARB2DEFRet
ARB2DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB2.
- STRING Return
ARB2Ret
ARB2Ret
ARB3
ARB3
Loads the binary-data to an existing arbitrary waveform memory location ARB3.
- UINT Waveform
ARB3DEFRet
ARB3DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB3.
- STRING Return
ARB3Ret
ARB3Ret
ARB4
ARB4
Loads the binary-data to an existing arbitrary waveform memory location ARB4.
- BYTE Waveform
ARB4DEFRet
ARB4DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
- STRING Return
ARB4Ret
ARB4Ret
ARBDCOFFS
ARBDCOFFS
Sets the arbritary dc waveform offset to <nrf> volts.
- FLOAT OffsetVoltage
Set the offset voltage
ARBDEF
ARBDEF
Sets user specified waveform name <cpd2> and waveform point interpollation state <cpd3> of arbitrary waveform memory location <cpd1>.
- STRING Name
Specified waveform name
- STRING State
Waveform interpolatino state
- STRING Location
Waveform memory location
ARBLOAD
ARBLOAD
<cpd> sets the output waveform type to <DC>,<SINC>, <EXPRISE>,<LOGRISE>,<RAMPUP>,<RAMPDN>, <TRIANG>,<SQUARE>, <ARB1>,<ARB2>,<ARB3>, <ARB4>, <"USERNAME1">, <"USERNAME2">, <"USERNAME3">, <"USERNAME4">.
- STRING Type
Waveform Type
ARBRESIZE
ARBRESIZE
Changes the size of arbritary waveform <cpd> to <nrf>.
- FLOAT Size
Size of waveform
- STRING Waveform
Arbritary Waveform
BEEP
BEEP
Sound one beep.
BEEPMODE
BEEPMODE
Set beep mode to; 0 = ON, 1 = OFF, 2 = WARN, 3 = ERROR.
- BYTE Mode
Sets the beep mode (0 = ON, 1 = OFF, 2 = WARN, 3 = ERROR).
BST
BST
Sets the burst mode to; 0 = <OFF>, 1 = <NCYC>, 2= <GATED>, 3 = <INFINITE>.
- BYTE MODE
Sets the burst mode (0 = OFF, 1 = NCYC, 2 = GATED, 3 = INFINITE).
BSTCOUNT
BSTCOUNT
Sets the burst count to <nrf> cycles, maximum 1048575 cycles.
- LONG Count
Sets the burst count in cycles (1 - 1048575).
BSTPER
BSTPER
Sets the burst trigger period to <nrf> seconds. (Lower limit: 1us - Upper limit: 500s).
- FLOAT Seconds
Duration of the burst trigger period in seconds.
BSTPHASE
BSTPHASE
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
- FLOAT Degrees
Sets the burst phase in degrees (-360 - 360)
BSTTRGPOL
BSTTRGPOL
Sets the burst trigger slope to; 0 = POS, 1 = NEG.
- BOOL Slope
Set the burst trigger slope (0 = POS, 1 = NEG).
BSTTRGSRC
BSTTRGSRC
Sets the burst trigger source to; 0 = INT, 1 = EXT, 2 = MAN.
- BYTE Source
Set the burst trigger source (0 = INT, 1 = EXT, 2 = MAN).
CALADJ
CALADJ
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
- FLOAT Calibrate
Adjust the selected calibration value (-100 - 100).
CALIBRATION
CALIBRATION
Sets the calibration mode to <START>, <SAVE>, or <ABORT>. <nrf> represents the calibration password.
- BYTE Mode
0 = START, 1 = SAVE, 2 = ABORT
- ULONG Password
Calibration password
CALSTEP
CALSTEP
Step to the next calibration point.
CALVALRet
CALVALRet
Returns the value from level calibration steps.
CLKSRC
CLKSRC
Sets the clock source to; 0 = INT, 1 = EXT.
- BOOL Source
Sets the clock source (0 = INT, 1 = EXT).
CLKSRRet
CLKSRRet
Returns the clock source <INT> or <EXT>.
- BOOL Return
CLS
CLS
Clears status byte register of the interface.
DCOFFS
DCOFFS
Sets the dc offset to <nrf> Volts. (Lower limit: -4.500 Vdc - Upper limit: 4.500 Vdc).
- FLOAT DCOffset
Sets the dc offset in Volts(Vdc) (4.500 Vdc - 4.500 Vdc).
EERRet
EERRet
Query and clear execution error number register.
- STRING Return
ESE
ESE
Sets the Standard Event Status Enable Register to the value of <nrf>.
- BYTE Value
Value of register 0-255
ESERet
ESERet
Returns the value in the Standard Event Status Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>.
ESESet
ESESet
Sets the standard event status enable register to the value of <nrf>. (Lower limit: 0 - Upper limit: 255)
- BYTE Value
Enable the register to this value. (0 - 255)
ESRRet
ESRRet
Returns the value in the standard event status register in <nr1>
FREQ
FREQ
Set the waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz).
- FLOAT Frequency
Sets the waveform frequency in Hertz(Hz) (1uHz - 50MHz).
HILVL
HILVL
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
- FLOAT HighLevel
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
IDNRet
IDNRet
Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
- STRING ReturnIDN
- STRING Return
ISTRet
ISTRet
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
- BOOL Return
LOCAL
LOCAL
Returns the instrument to local opertion and unlocks the keyboard.
LOCKMODE
LOCKMODE
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
- BYTE Mode
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
LOLVL
LOLVL
Sets the amplitude-low-level to <nrf> Volts. (Lower limit: 5.000 V - Upper limit: -0.010 V).
- FLOAT LowLevel
Sets the amplitude-low-level in Volts(V) (-5.000 V - -0.010 V).
LRN
LRN
Intall data from a previous *LRN? command.
LRNRet
LRNRet
Returns the complete setup of the instrument as a binary data block
- INT Return
MOD
MOD
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
- BYTE Modulation
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
MODAMDEPTH
MODAMDEPTH
Sets AM waveform depth to <nrf> %. (Lower limit: 0% - Upper limit: 120%).
- FLOAT Frequency
Sets AM waveform depth in percent (%) (0 - 120).
MODAMFREQ
MODAMFREQ
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
- FLOAT Frequency
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
MODAMSHAPE
MODAMSHAPE
Sets AM waveform shape to: 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE Shape
Sets AM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
MODAMSRC
MODAMSRC
Sets AM waveform source to; 0 = INT, 1 = EXT.
- BOOL Source
Sets AM waveform source (0 = INT, 1 = EXT).
MODFMDEV
MODFMDEV
Sets FM waveform deviation to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 25MHz).
- FLOAT Deviation
Sets FM waveform deviation in Hertz(Hz) (1uHz - 25MHz).
MODFMFREQ
MODFMFREQ
Sets FM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
- FLOAT Frequency
Sets FM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
MODFMSHAPE
MODFMSHAPE
Sets FM waveform shape to: 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE Shape
Sets FM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
MODFMSRC
MODFMSRC
Sets FM waveform source to; 0 INT, 1 = EXT.
- BOOL Source
Sets FM waveform source (0 = INT, 1 = EXT).
MODFSKRATE
MODFSKRATE
Sets FSK rate to <nrf> Hz. (Lower limit: 2mHz - Upper limit: 100kHz).
- FLOAT Rate
Sets FSK rate in Hertz(Hz) (2mHz - 100kHz).
MODFSKSRC
MODFSKSRC
Sets FSK waveform source to; 0 = INT, 1 = EXT.
- BOOL Source
Sets FSK waveform source (0 = INT, 1 = EXT).
MODHOPFREQ
MODHOPFREQ
Sets HOP frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz).
- FLOAT Frequency
Sets HOP frequency in Hertz(Hz) (1uHz - 50MHz).
MODPMDEV
MODPMDEV
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
- FLOAT Degrees
Sets PM waveform deviation in degrees (-360 - 360).
MODPMFREQ
MODPMFREQ
Sets PM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
- FLOAT Frequency
MODPMSHAPE
MODPMSHAPE
Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE Shape
Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
MODPMSRC
MODPMSRC
Sets PM waveform source to; 0 INT, 1 = EXT.
- BOOL Source
Sets PM waveform source (0 = INT, 1 = EXT).
MODPOLFSK
MODPOLFSK
Sets FSK trigger slope to; 0 = POS, 1 = NEG.
- BOOL Slope
Set FSK trigger slope (0 = POS, 1 = NEG).
MODPWMDEVSYM
MODPWMDEVSYM
Sets PWM deviation to <nrf> %. ?
- BYTE Deviation
Sets PWM waveform deviation in percent. (?)
MODPWMDEVWDT
MODPWMDEVWDT
Sets the PWM waveform deviation to <nrf> sec.
- FLOAT Sec
MODPWMFREQ
MODPWMFREQ
Sets PWM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
- FLOAT Frequency
Sets PWM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
MODPWMSHAPE
MODPWMSHAPE
Sets PWM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE Shape
Sets PWM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
MODPWMSRC
MODPWMSRC
Sets PWM waveform source to; 0 = INT, 1 = EXT.
- BOOL Source
Sets PWM waveform source (0 = INT, 1 = EXT).
MSTLOCK
MSTLOCK
Sends signal to SLAVE generator to get synchronised
MSTRELOCK
MSTRELOCK
Resynchronises the two generators in MASTER-SLAVE mode.
NOISADD
NOISADD
Select <ON> to add the noise to the output waveform and <OFF> to remove the noise from the output waveform. 0 = ON, 1 = OFF.
- BOOL Noise
Add/remove the noise to/from the output waveform (0 = ON, 1 = OFF).
NOISLVL
NOISLVL
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
- BYTE Percent
Sets the output noise level in percent. (0 - 50)
OPC
OPC
Sets the Operation Complete bit (bit 0) in the Standard Event Status Register. This will happen immediately the command is executed because of the sequential nature of all operations.
OPCRet
OPCRet
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
- BOOL Return
OUTPUT
OUTPUT
Sets the output to; 0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT.
- BYTE SetOutput
Set the output. (0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT).
PER
PER
Sets the waveform period to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms)
- FLOAT Period
Duration of the waveform period in seconds (20ns - 1Ms).
PRE
PRE
Sets the Parallel Port Enable Register to the value <nrf>.
- BYTE Status
Set register value 0-255
PRERet
PRERet
Returns the value in the Parallel Poll Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>.
PULSDLY
PULSDLY
Sets the waveform delay to <nrf> sec
- FLOAT Sec
PULSEDGE
PULSEDGE
Sets the pulse waveform edges (positive and negative edge) to <nrf> micro Sec. Value zero sets to the minimum value allowed (Lower limit: 5ns - Upper limit: 40us).
- FLOAT Edges
Sets the pulse waveform edges in micro seconds (5ns - 40us).
PULSFALL
PULSFALL
Sets the pulse waveform negative edge to <nrf> micro seconds. (Lower limit: 5ns - Upper limit: 99.9ns).
- FLOAT Fall
Sets the pulse waveform negative edge in micro seconds (5ns - 99.9ns).
PULSFREQ
PULSFREQ
Sets the pulse waveform frequency to <nrf> Hz (Lower limit: 1uHz - Upper limit: 50MHz).
- FLOAT Frequency
Sets the pulse waveform frequency in Hertz(Hz) (1uHz - 50MHz).
PULSPER
PULSPER
Sets the pulse waveform period to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms).
- FLOAT Period
Duration of the pulse waveform period (20ns - 1Ms).
PULSRANGE
PULSRANGE
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
- BYTE Range
Sets the pulse rise and fall range. (1, 2 or 3)
PULSRISE
PULSRISE
- FLOAT Rise
Sets the pulse waveform positive edge in micro seconds (5ns - 99.9ns).
PULSSYMM
PULSSYMM
Sets the pulse waveform symmetry to <nrf> %. (Lower limit: 0 - Upper limit: 100)
- FLOAT Symmetry
Sets the pulse waveform symmetry in percent. (0 - 100)
PULSWID
PULSWID
Sets the pulse waveform width to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms).
- FLOAT Seconds
Sets the pulse waveform width in seconds (20ns - 1Ms).
QERRet
QERRet
Query and clear error register
RCL
RCL
Recalls the instrument setup contained in store <nrf>.
- BYTE StoreLocation
Memory location (0-9)
RMPSYMM
RMPSYMM
Sets the ramp waveform symmetry to <nrf> %. (Lower limit: 0 - Upper limit: 100)
- FLOAT Symmetry
Sets the ramp waveform symmetry in percent (0 - 100).
RST
RST
Resets the instrument parameters to their default values.
SAV
SAV
Saves the complete instrument setup to the setup-file named <nrf>
Memory location of register (0-9)
SLVRST
SLVRST
Sets the SLAVE generator ready to be synchronised
SQRSYMM
SQRSYMM
Sets the square waveform symmetry to <nrf> %. (Lower limit: 20 - Upper limit: 80)
- FLOAT Symmetry
Sets the square waveform symmetry in percent (20 - 80).
SRE
SRE
Set the Service Request Enable Register to <nrf>.
- BYTE Status
SRERet
SRERet
Returns the value of the Service Request Enable Register in <nr1> numeric format.
STBRet
STBRet
Returns the value of the Status Byte Register in <nr1> numeric format.
SWP
SWP
Sets the sweep to <ON> or <OFF>. 0 = ON, 1 = OFF.
- BOOL Sweep
Enable or disable the sweep (0 = ON, 1 = OFF).
SWPBEGFREQ
SWPBEGFREQ
Sets the sweep start frequency to <nrf> Hz (Lower limit: 1uHz - Upper limit: 100kHz)
- FLOAT Frequency
Sets the sweep start frequency in Hertz(Hz) (1uHz - 100kHz).
SWPCNTFREQ
SWPCNTFREQ
Sets the sweep centre frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz).
- FLOAT Frequency
Sets the sweep centre frequency in Hertz(Hz) (1uHz - 50MHz).
SWPENDFREQ
SWPENDFREQ
Sets the sweep centre frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz.)
- FLOAT Frequency
Set the sweep end frequency in Hertz(Hz) (1uHz - 50MHz).
SWPMKR
SWPMKR
Sets the sweep marker to <ON> or <OFF>. 0 = ON, 1 = OFF.
- BOOL Marker
Enable or disable the sweep marker (0 = ON, 1 = OFF).
SWPMKRFREQ
SWPMKRFREQ
Sets the sweep marker to <nrf> Hz. (Lower limit: 10kHz - Upper limit: 100kHz).
- FLOAT Frequency
Set the sweep marker in Hertz(Hz) (10kHz - 100kHz).
SWPMODE
SWPMODE
Sets the sweep mode to <CONT> or <TRIG>. 0 = CONT, 1 = TRIG.
- BOOL Mode
Set the sweep mode (0 = CONT, 1 = TRIG).
SWPSPNFREQ
SWPSPNFREQ
Sets the sweep frequency span to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50.25kHz).
- FLOAT Frequency
Set the sweep frequency span in Hertz(Hz) (1uHz - 50.25kHz).
SWPTIME
SWPTIME
Sets the sweep time to <nrf> seconds
- FLOAT Seconds
Set the sweep time in seconds.
SWPTRGPER
SWPTRGPER
Sets the sweep trigger period to <nrf> seconds
- FLOAT Seconds
Set the sweep trigger period in seconds.
SWPTRGPOL
SWPTRGPOL
Sets the sweep trigger slope to; 0 = POS, 1 = NEG.
- BOOL Slope
Set the sweep trigger slope (0 = POS, 1 = NEG).
SWPTRGSRC
SWPTRGSRC
Sets the sweep trigger source to; 0 = INT, 1 = EXT, 2 = MAN.
- BYTE Source
Set the sweep trigger source (0 = INT, 1 = EXT, 2 = MAN).
SWPTYPE
SWPTYPE
Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
- BYTE Type
Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
SYNCOUT
SYNCOUT
Sets the sync output to; 0 = ON, 1 = OFF.
- BOOL Sync
Enable/disable sync output (0 = ON, 1 = OFF).
SYNCTYPE
SYNCTYPE
Sets the sync type to; 0 = AUTO, 1 = CARRIER, 2 = MODULATION, 3 = SWEEP, 4 = BURST, 5 = TRIGGER.
- BYTE Type
Set the sync type (0 = AUTO, 1 = CARRIER, 2 = MODULATION, 3 = SWEEP, 4 = BURST, 5 = TRIGGER).
TRG
TRG
This command is the same as pressing the TRIGGER key.
TSTRet
TSTRet
The generator has no self test capability and the response is always 0 <rmt>.
- BOOL Return
WAI
WAI
Wait for Operation Complete true. As all commands are fully executed before the next is started this command takes no additional action.
WAVE
WAVE
Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
- BYTE WaveType
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
WAVELVL
WAVELVL
Sets the output waveform level to <nr1> %. (Lower limit: 50 - Upper limit: 100)
- FLOAT Percent
Sets the output waveform level in percent (50 - 100).
ZLOAD
ZLOAD
sets the output load, which the generator is to assume for amplitude and dc offset entries, to; 0 = OPEN or 1 - 10,000
- INT Output
Sets the output load for amplitude and dc offset entires (0 = OPEN or 1 -10,000).
COM Port
Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
