Component: Delay (DSP Operators)
| Author | Matrix Ltd |
| Version | 1.2 |
| Category | DSP Operators |
Delay component
Allows an adjustable delay to be inserted into the DSP system
Here is a simple example file for the Delay component.
The DelayADC component is used to set the amount of delay that the component provides 0-2550 samples in steps of 10 samples.
The Input ADC component is used to pass a variable value into the DSP chain to allow the delay to be simulated.
Here is a picture showing the response of the delay component using the data recorder window.
Delay
| Delay | |
| Passes a single value from a buffer into the delay buffer and spits out a delayed value at the other end | |
DelayArray
| DelayArray | |
| Passes an entire buffer into the delay buffer and spits out a delayed version of the buffer at the other end | |
PresetDelay
| PresetDelay | |
| Presets the contents of the delay buffer with the specified value. | |
| Value | |
SetDelaySize
| SetDelaySize | |
| Specifies the number of values in the delay buffer to allow the length of the delay to be adjustable during runtime. | |
| Delay_Count | |
Please click here to download the component source project: FC_Comp_Source_DSP_Delay.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Delay.fcfx
