Component: LCD (Adafruit, 16x2) (Alphanumeric)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 1.8
Category Alphanumeric
LCD (Adafruit, 16x2) component
Adafruit OLED LCD display capable of displaying 2 lines of 16 characters.
Please click here to download the component source project: FC_Comp_Source_LCD_Adafruit_OLED.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_Adafruit_OLED.fcfx
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
A simple example that shows how to use some common functions.
Adafruit LCD Example
Clear
Clear
ClearLine
ClearLine
Clears a single line on the display before moving the cursor back to the start of the line to allow new data to be displayed.
- BYTE Line
Command
Command
- BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
Cursor
Cursor
- BYTE x
- BYTE y
PrintAscii
PrintAscii
- BYTE character
Holds an ascii value.
PrintFloat
PrintFloat
- FLOAT Number
- BYTE DecimalPlaces
PrintFormattedNumber
- ULONG Number
- BOOL Format
0=Signed, 1=Unsigned
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
PrintString
PrintString
- STRING Text
RAMWrite
RAMWrite
- BYTE Index
Values 0 to 7
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
ScrollDisplay
ScrollDisplay
- BYTE Position
Holds the number of positions to shift the display
- BYTE direction
0 = left, 1 = right
Start
Start
Startup routine required by the hardware device. Automatically clears the display when complete.
Data 0 (11)
Data pin 0 connects to data pin 4 on the hardware
Data 1 (12)
Data pin 1 connects to data pin 5 on the hardware
Data 2 (13)
Data pin 2 connects to data pin 6 on the hardware
Data 3 (14)
Data pin 3 connects to data pin 7 on the hardware
Register Select (4)
Register select pin, determines if the incoming value is a command or a data byte
Read / Write (5)
Read / Write pin determines the data direction
Enable (6)
Enable pin, used to clock data in and out of the device.
Display Settings
Rows
Number of lines of characters the LCD can display.
Columns
Number of characters the LCD can display on a single line.
Component Label
Component Label Scale
Text Colour
Colour of the font characters drawn on the display
Text Background
Colour surrounding the font characters drawn on the display
Display Background
Colour of the background of the display
