Component: WLAN (EB069, WIZ610wi) (Misc)
| Author | Matrix Ltd. |
| Version | 1.3 |
| Category | Misc |
WLAN (EB069, WIZ610wi) component
Wireless LAN component designed to work with the WIZ610wi module from Wiznet. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the EB069 E-block.
Please click here to download the component source project: FC_Comp_Source_WLAN.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN.fcfx
CheckForPageRequests
| CheckForPageRequests | |
| To be called periodically. Returns non-zero if a request has been processed | |
ConnectToSSID
| ConnectToSSID | |
| Attempts to connect to the given SSID and Key values. Returns 0 if successful. | |
| SSID | |
| Key | |
DisableCommandMode
| DisableCommandMode | |
| Exits command mode | |
EnableCommandMode
| EnableCommandMode | |
| Enables command mode. Must be called before commands are issued. | |
GetInValue
| GetInValue | |
| Returns the string value of a Request parameter | |
| index | |
| Index of the request paramter, starting at zero. | |
GetReply
| GetReply | |
| Returns the last received response to a command. 0 = OK 1 = FAIL_ERR 2 = STX_ERR 3 = CMD_ERR 4 = PARAM_ERR 5 = ETX_ERR 6 = SERIAL 255 = TOUT | |
| Initialise the device with the property data. Returns 0 if successful | |
ReadConnectionStatus
| ReadConnectionStatus | |
| Checks the connection status. Returns 0 if not connected, 1 if connected. | |
ReceiveIncoming
| ReceiveIncoming | |
| Returns the received data string | |
SendCommand
| SendCommand | |
| Sends the given command and returns the reply status. (See GetReply for return values) | |
| Command | |
SendString
| SendString | |
| Sends the given Text. Appends a CR/LF pair of characters it CrLf is true. | |
| Text | |
| CrLf | |
Send_Embedded_HTML_Page1
Send_Embedded_HTML_Page2
Send_Embedded_HTML_Page3
Send_Embedded_HTML_Page4
SetOutValue
| SetOutValue | |
| Set the value of an outbound substitution string | |
| index | |
| value | |
