Component: Touch Screen (GT911) (Graphical Library)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 2.0
Category Graphical Library
Touch Screen (GT911) component
Low level routines for controlling or interacting with the GT911 touch screen controller IC found on a lot of common capacitive touch screen products.
Version information
6, 1.0, 26-07-24, BR, Removed ghost greay square connection line
7, 1.0, 29-08-24, BR, Fixed a problem where the I2C writes were corrupted
8, 1.0, 29-08-24, BR, Added Orientation support
9, 1.0, 29-08-24, BR, Improved Orientation support
Activates the SPI peripheral and claims control over the I/O pins. Returns 1 if device found and communicating.
- BOOL Return
ReadCoord
ReadCoord
Reads a coordinate returned from the Sample Sensor macro. Coordinate is scaled to the X/Y Pixel bounds specified.
- BYTE Coordinate
0 = X, 1 = Y, 2 = PointSize, 3= TrackID
- BYTE Index
Touch Index Range: 0 - 4
ReadXBytes
ReadXBytes
Reads the specified number of bytes starting at the specified address
- UINT Address
- BYTE Data
- BYTE NumBytes
- BOOL Return
SampleSensor
SampleSensor
Reads the touch controller and returns true if there is currently a touch in progress. The touch coordinates can be read using the ReadCoord macro. Return 0 = No Touch, 1 = Single touch detected, 2 = Two touch points detected
SetOrientation
SetOrientation
Allows the orientation to be overridden.
- BYTE Orientation
Range: 0 - 3
WriteXBytes
WriteXBytes
Writes the specified number of bytes starting at the specified address
- UINT Address
- BYTE Data
- BYTE NumBytes
LinkTo
Bus Settings
Channel selection
Baud Select
Baud rate to be used
Stop Delay
Device Address
The device address is set using the INT pin on power up. Low = 0x5D / High = 0x14
SDA
SCL
Reset Pin
Pin used to reset the touch module
INT Pin
Pin used to set the I2C address and check for new touch data.
Configuration
Analogue Mode
X Pixel
Y Pixel
Flip X
Flip Y
Label used to identify the component on the panel.
Enable Interrupt
Interrupt Macro
Macro called when the simulated display fires an interrupt.
Simulate Comms
Allows the I2C communications to be simulated and piped through an API to real world hardware.
Please click here to download the component source project: FC_Comp_Source_TouchScreen_GT911.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TouchScreen_GT911.fcfx
