Component: RFID (Sparkfun Quiic / ID-12LA) (15209) (Wireless)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category Wireless
RFID (Sparkfun Quiic / ID-12LA) component
Provides functions to drive the Sparkfun Quiic RFID reader module (ID-12LA). Allowing access to read 125KHz RFID tags. Suitable for applications such as tracking, logging or access control.
Please click here to download the component source project: FC_Comp_Source_RFID_Sparkfun_Quiic.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RFID_Sparkfun_Quiic.fcfx
ChangeI2CAddress
ChangeI2CAddress
Allows the I2C Device address to be changed which in turn allows more then one RFID reader to sit on the same physical I2C bus. Returns 1 if succesful.
- BYTE NewAddress
Range: 7 to 120 or 0x07 - 0x78
- BOOL Return
CheckForTag
CheckForTag
Checks to see if a tag has been detected by the module. Returns 1 if tag has been detected. Tag ID and Time since read can be accessed using GetTag and GetTime macros.
- BOOL Return
GetTag
GetTag
Gets the tag ID returned as a byte array. Must be called after CheckForTag has returned true. Byte array variable should be at least 6 bytes long.
- BYTE Data
GetTagString
GetTagString
Gets the tag ID returned as a string. Must be called after CheckForTag has returned true. String variable should be at least 13 characters long.
- STRING Return
GetTimeMS
GetTimeMS
Gets the time in milliseconds since the tag was read by the module. Must be called after CheckForTag has returned true.
- ULONG Return
GetTimeS
GetTimeS
Gets the time in seconds since the tag was read by the module. Must be called after CheckForTag has returned true.
Initialises the I2C bus ready for communications with the module. Wipes the tag ID storage ready for data to be stored.
IsKnownID
IsKnownID
Checks to see if the last tag read by CheckForTag is saved into memory. Returns true if tag is stored in memory.
- BOOL Return
RemoveCurrentTag
RemoveCurrentTag
Removes the current Tag ID from the known tag storage.
RemoveTagID
RemoveTagID
Removes a specific 6-byte tag ID from the known tag storage
- BYTE ID
Array of 6 bytes containing tag ID
StoreCurrentTag
StoreCurrentTag
Stores the current detected tag as a known tag storage Returns true if the tag has been stored or false if there is no remaining room
- BOOL Return
StoreTagID
StoreTagID
Stores a specific 6-byte tag ID into the known storage Returns true if the tag has been stored or false if there is no remaining room
- BYTE ID
- BOOL Return
Device Address
External device address used to communicate with the module. Default 125 or 0x7D
Stored Tag Count
Number of tags IDs to store as valid IDs for use with IsKnownID. For example max number of users for a door entry system. Each stored ID requires 6 bytes of RAM memory. Max 42.
Channel selection
Baud Select
Baud rate to be used
SDA
SCL
Stop Delay
API
