Component: Accelerometer 3-Axis (LIS3LV02DQ) (Movement Orientation)
Author Matrix Ltd.
Version 2.0
Category Movement Orientation
Accelerometer 3-Axis (LIS3LV02DQ) component
LIS3LV02DQ Accelerometer sensor with options for I2C or SPI communications. Useful for approximating Pitch and Roll or for detecting acceleration. Also available in the form of the EB068 Accelerometer E-block.
Please click here to download the component source project: FC_Comp_Source_Accelerometer_LIS3LV0DQ.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Accelerometer_LIS3LV0DQ.fcfx
Simple example showing a basic digital sprit level using a gLCD.
Digital sprit level
CollectXYZData
CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
- BYTE Axis
- INT Return
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
SimReset1G
SimReset1G
Resets the simulation to 0.0 on X and Y and 1.0 on Z as if the accelerometer was sitting completely horizontal.
SimSetXYZ
SimSetXYZ
Allows the XYZ slider values to be set via the simulation
- INT X
- INT Y
- INT Z
UpdateXYZData
UpdateXYZData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
Bit Depth
The number of binary bits used to store the sensor's X,Y,Z readings.
Bus Type
The interface used to talk to the accelerometer. I2C - Two Wire Interface SDA / SCL SPI - Four Wire Interface MISO / MOSI / SCK / CS
Data Rate
Configures how often the sensor collects a new reading. More often = better instant reaction to new events Less often = more stable results
Scale
The accelerometer readings are scaled based on the maximum amount of G force the sensor can represent. 6G = Bigger gravitational force 2G = Higher resolution
Int Option
Sets if we use the interrupt pin to check if new data is available
Power Option
Sets if the sensor is always powered or powered via a microcontroller output pin.
SPI Connections
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Simulation Coms
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the CAL component - I2C or SPI - API etc
