Component: TTI TG5011 Signal Generator (TG5011) (Test Equipment)
| Version | 0.2 |
| Category | Test Equipment |
TTI TG5011 Signal Generator component
TTi TG5011 50 MHz Signal Generator
Please click here to download the component source project: FC_Comp_Source_TTITG5011.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_TTITG5011.fcsx
ADDRESSRet
| ADDRESSRet | |
| Returns the instruments address | |
AMPL
AMPLRNG
| AMPLRNG | |
| Sets the amplitude range to; 0 = AUTO, 1 = HOLD. | |
| Range | |
| Sets the amplitude range (0 = AUTO, 1 = HOLD). | |
AMPUNIT
| AMPUNIT | |
| Sets the amplitude units to; 0 = VPP, 1 = VRMS, 2 = DBM. | |
| Units | |
| Sets the amplitude units (0 = VPP, 1 = VRMS, 2 = DBM). | |
ARB1
| ARB1 | |
| Loads the binary-data to an existing arbitrary waveform memory location ARB1. | |
| Waveform | |
| 16 Bit binary number for arbitrary waveform. | |
ARB1DEFRet
| ARB1DEFRet | |
| Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB1. | |
ARB1Ret
| ARB1Ret | |
| Returns the binary-data from an existing abbitrary wavefrom memory location. | |
ARB2
| ARB2 | |
| Loads the binary-data to an existing arbitrary waveform memory location ARB2. | |
| Waveform | |
ARB2DEFRet
| ARB2DEFRet | |
| Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB2. | |
ARB2Ret
| ARB2Ret | |
ARB3
| ARB3 | |
| Loads the binary-data to an existing arbitrary waveform memory location ARB3. | |
| Waveform | |
ARB3DEFRet
| ARB3DEFRet | |
| Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB3. | |
ARB3Ret
| ARB3Ret | |
ARB4
| ARB4 | |
| Loads the binary-data to an existing arbitrary waveform memory location ARB4. | |
| Waveform | |
ARB4DEFRet
| ARB4DEFRet | |
| Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4. | |
ARB4Ret
| ARB4Ret | |
ARBDCOFFS
| ARBDCOFFS | |
| Sets the arbritary dc waveform offset to <nrf> volts. | |
| OffsetVoltage | |
| Set the offset voltage | |
ARBDEF
ARBLOAD
ARBRESIZE
| ARBRESIZE | |
| Changes the size of arbritary waveform <cpd> to <nrf>. | |
| Size | |
| Size of waveform | |
| Waveform | |
| Arbritary Waveform | |
BEEP
| BEEP | |
| Sound one beep. | |
BEEPMODE
| BEEPMODE | |
| Set beep mode to; 0 = ON, 1 = OFF, 2 = WARN, 3 = ERROR. | |
| Mode | |
| Sets the beep mode (0 = ON, 1 = OFF, 2 = WARN, 3 = ERROR). | |
BST
| BST | |
| Sets the burst mode to; 0 = <OFF>, 1 = <NCYC>, 2= <GATED>, 3 = <INFINITE>. | |
| MODE | |
| Sets the burst mode (0 = OFF, 1 = NCYC, 2 = GATED, 3 = INFINITE). | |
BSTCOUNT
| BSTCOUNT | |
| Sets the burst count to <nrf> cycles, maximum 1048575 cycles. | |
| Count | |
| Sets the burst count in cycles (1 - 1048575). | |
BSTPER
| BSTPER | |
| Sets the burst trigger period to <nrf> seconds. (Lower limit: 1us - Upper limit: 500s). | |
| Seconds | |
| Duration of the burst trigger period in seconds. | |
BSTPHASE
| BSTPHASE | |
| Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360) | |
| Degrees | |
| Sets the burst phase in degrees (-360 - 360) | |
BSTTRGPOL
| BSTTRGPOL | |
| Sets the burst trigger slope to; 0 = POS, 1 = NEG. | |
| Slope | |
| Set the burst trigger slope (0 = POS, 1 = NEG). | |
BSTTRGSRC
| BSTTRGSRC | |
| Sets the burst trigger source to; 0 = INT, 1 = EXT, 2 = MAN. | |
| Source | |
| Set the burst trigger source (0 = INT, 1 = EXT, 2 = MAN). | |
CALADJ
| CALADJ | |
| Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100). | |
| Calibrate | |
| Adjust the selected calibration value (-100 - 100). | |
CALIBRATION
CALSTEP
| CALSTEP | |
| Step to the next calibration point. | |
CALVALRet
| CALVALRet | |
| Returns the value from level calibration steps. | |
CLKSRC
| CLKSRC | |
| Sets the clock source to; 0 = INT, 1 = EXT. | |
| Source | |
| Sets the clock source (0 = INT, 1 = EXT). | |
CLKSRRet
| CLKSRRet | |
| Returns the clock source <INT> or <EXT>. | |
CLS
| CLS | |
| Clears status byte register of the interface. | |
DCOFFS
| DCOFFS | |
| Sets the dc offset to <nrf> Volts. (Lower limit: -4.500 Vdc - Upper limit: 4.500 Vdc). | |
| DCOffset | |
| Sets the dc offset in Volts(Vdc) (4.500 Vdc - 4.500 Vdc). | |
EERRet
| EERRet | |
| Query and clear execution error number register. | |
ESE
| ESE | |
| Sets the Standard Event Status Enable Register to the value of <nrf>. | |
| Value | |
| Value of register 0-255 | |
ESERet
| ESERet | |
| Returns the value in the Standard Event Status Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>. | |
ESESet
| ESESet | |
| Sets the standard event status enable register to the value of <nrf>. (Lower limit: 0 - Upper limit: 255) | |
| Value | |
| Enable the register to this value. (0 - 255) | |
ESRRet
| ESRRet | |
| Returns the value in the standard event status register in <nr1> | |
FREQ
| FREQ | |
| Set the waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz). | |
| Frequency | |
| Sets the waveform frequency in Hertz(Hz) (1uHz - 50MHz). | |
HILVL
| HILVL | |
| Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V). | |
| HighLevel | |
| Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V). | |
IDNRet
ISTRet
| ISTRet | |
| Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true. | |
LOCAL
| LOCAL | |
| Returns the instrument to local opertion and unlocks the keyboard. | |
LOCKMODE
| LOCKMODE | |
| Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP. | |
| Mode | |
| Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP). | |
LOLVL
| LOLVL | |
| Sets the amplitude-low-level to <nrf> Volts. (Lower limit: 5.000 V - Upper limit: -0.010 V). | |
| LowLevel | |
| Sets the amplitude-low-level in Volts(V) (-5.000 V - -0.010 V). | |
LRN
| LRN | |
| Intall data from a previous *LRN? command. | |
LRNRet
| LRNRet | |
| Returns the complete setup of the instrument as a binary data block | |
MOD
| MOD | |
| Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM. | |
| Modulation | |
| Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM). | |
MODAMDEPTH
| MODAMDEPTH | |
| Sets AM waveform depth to <nrf> %. (Lower limit: 0% - Upper limit: 120%). | |
| Frequency | |
| Sets AM waveform depth in percent (%) (0 - 120). | |
MODAMFREQ
| MODAMFREQ | |
| Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
| Frequency | |
| Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
MODAMSHAPE
MODAMSRC
| MODAMSRC | |
| Sets AM waveform source to; 0 = INT, 1 = EXT. | |
| Source | |
| Sets AM waveform source (0 = INT, 1 = EXT). | |
MODFMDEV
| MODFMDEV | |
| Sets FM waveform deviation to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 25MHz). | |
| Deviation | |
| Sets FM waveform deviation in Hertz(Hz) (1uHz - 25MHz). | |
MODFMFREQ
| MODFMFREQ | |
| Sets FM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
| Frequency | |
| Sets FM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
MODFMSHAPE
MODFMSRC
| MODFMSRC | |
| Sets FM waveform source to; 0 INT, 1 = EXT. | |
| Source | |
| Sets FM waveform source (0 = INT, 1 = EXT). | |
MODFSKRATE
| MODFSKRATE | |
| Sets FSK rate to <nrf> Hz. (Lower limit: 2mHz - Upper limit: 100kHz). | |
| Rate | |
| Sets FSK rate in Hertz(Hz) (2mHz - 100kHz). | |
MODFSKSRC
| MODFSKSRC | |
| Sets FSK waveform source to; 0 = INT, 1 = EXT. | |
| Source | |
| Sets FSK waveform source (0 = INT, 1 = EXT). | |
MODHOPFREQ
| MODHOPFREQ | |
| Sets HOP frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz). | |
| Frequency | |
| Sets HOP frequency in Hertz(Hz) (1uHz - 50MHz). | |
MODPMDEV
| MODPMDEV | |
| Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°). | |
| Degrees | |
| Sets PM waveform deviation in degrees (-360 - 360). | |
MODPMFREQ
| MODPMFREQ | |
| Sets PM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
| Frequency | |
MODPMSHAPE
MODPMSRC
| MODPMSRC | |
| Sets PM waveform source to; 0 INT, 1 = EXT. | |
| Source | |
| Sets PM waveform source (0 = INT, 1 = EXT). | |
MODPOLFSK
| MODPOLFSK | |
| Sets FSK trigger slope to; 0 = POS, 1 = NEG. | |
| Slope | |
| Set FSK trigger slope (0 = POS, 1 = NEG). | |
MODPWMDEVSYM
| MODPWMDEVSYM | |
| Sets PWM deviation to <nrf> %. ? | |
| Deviation | |
| Sets PWM waveform deviation in percent. (?) | |
MODPWMDEVWDT
| MODPWMDEVWDT | |
| Sets the PWM waveform deviation to <nrf> sec. | |
| Sec | |
MODPWMFREQ
| MODPWMFREQ | |
| Sets PWM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
| Frequency | |
| Sets PWM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
MODPWMSHAPE
MODPWMSRC
| MODPWMSRC | |
| Sets PWM waveform source to; 0 = INT, 1 = EXT. | |
| Source | |
| Sets PWM waveform source (0 = INT, 1 = EXT). | |
MSTLOCK
| MSTLOCK | |
| Sends signal to SLAVE generator to get synchronised | |
MSTRELOCK
| MSTRELOCK | |
| Resynchronises the two generators in MASTER-SLAVE mode. | |
NOISADD
NOISLVL
| NOISLVL | |
| Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%) | |
| Percent | |
| Sets the output noise level in percent. (0 - 50) | |
OPC
OPCRet
| OPCRet | |
| Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential. | |
OUTPUT
| OUTPUT | |
| Sets the output to; 0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT. | |
| SetOutput | |
| Set the output. (0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT). | |
PER
| PER | |
| Sets the waveform period to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms) | |
| Period | |
| Duration of the waveform period in seconds (20ns - 1Ms). | |
PRE
| PRE | |
| Sets the Parallel Port Enable Register to the value <nrf>. | |
| Status | |
| Set register value 0-255 | |
PRERet
| PRERet | |
| Returns the value in the Parallel Poll Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>. | |
PULSDLY
| PULSDLY | |
| Sets the waveform delay to <nrf> sec | |
| Sec | |
PULSEDGE
PULSFALL
PULSFREQ
| PULSFREQ | |
| Sets the pulse waveform frequency to <nrf> Hz (Lower limit: 1uHz - Upper limit: 50MHz). | |
| Frequency | |
| Sets the pulse waveform frequency in Hertz(Hz) (1uHz - 50MHz). | |
PULSPER
| PULSPER | |
| Sets the pulse waveform period to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms). | |
| Period | |
| Duration of the pulse waveform period (20ns - 1Ms). | |
PULSRANGE
| PULSRANGE | |
| Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3. | |
| Range | |
| Sets the pulse rise and fall range. (1, 2 or 3) | |
PULSRISE
PULSSYMM
| PULSSYMM | |
| Sets the pulse waveform symmetry to <nrf> %. (Lower limit: 0 - Upper limit: 100) | |
| Symmetry | |
| Sets the pulse waveform symmetry in percent. (0 - 100) | |
PULSWID
| PULSWID | |
| Sets the pulse waveform width to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms). | |
| Seconds | |
| Sets the pulse waveform width in seconds (20ns - 1Ms). | |
QERRet
| QERRet | |
| Query and clear error register | |
RCL
| RCL | |
| Recalls the instrument setup contained in store <nrf>. | |
| StoreLocation | |
| Memory location (0-9) | |
RMPSYMM
| RMPSYMM | |
| Sets the ramp waveform symmetry to <nrf> %. (Lower limit: 0 - Upper limit: 100) | |
| Symmetry | |
| Sets the ramp waveform symmetry in percent (0 - 100). | |
RST
| RST | |
| Resets the instrument parameters to their default values. | |
SAV
| SAV | |
| Saves the complete instrument setup to the setup-file named <nrf> | |
| StoreLocation | |
| Memory location of register (0-9) | |
SLVRST
| SLVRST | |
| Sets the SLAVE generator ready to be synchronised | |
SQRSYMM
| SQRSYMM | |
| Sets the square waveform symmetry to <nrf> %. (Lower limit: 20 - Upper limit: 80) | |
| Symmetry | |
| Sets the square waveform symmetry in percent (20 - 80). | |
SRE
| SRE | |
| Set the Service Request Enable Register to <nrf>. | |
| Status | |
SRERet
| SRERet | |
| Returns the value of the Service Request Enable Register in <nr1> numeric format. | |
STBRet
| STBRet | |
| Returns the value of the Status Byte Register in <nr1> numeric format. | |
SWP
| SWP | |
| Sets the sweep to <ON> or <OFF>. 0 = ON, 1 = OFF. | |
| Sweep | |
| Enable or disable the sweep (0 = ON, 1 = OFF). | |
SWPBEGFREQ
| SWPBEGFREQ | |
| Sets the sweep start frequency to <nrf> Hz (Lower limit: 1uHz - Upper limit: 100kHz) | |
| Frequency | |
| Sets the sweep start frequency in Hertz(Hz) (1uHz - 100kHz). | |
SWPCNTFREQ
| SWPCNTFREQ | |
| Sets the sweep centre frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz). | |
| Frequency | |
| Sets the sweep centre frequency in Hertz(Hz) (1uHz - 50MHz). | |
SWPENDFREQ
| SWPENDFREQ | |
| Sets the sweep centre frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz.) | |
| Frequency | |
| Set the sweep end frequency in Hertz(Hz) (1uHz - 50MHz). | |
SWPMKR
| SWPMKR | |
| Sets the sweep marker to <ON> or <OFF>. 0 = ON, 1 = OFF. | |
| Marker | |
| Enable or disable the sweep marker (0 = ON, 1 = OFF). | |
SWPMKRFREQ
| SWPMKRFREQ | |
| Sets the sweep marker to <nrf> Hz. (Lower limit: 10kHz - Upper limit: 100kHz). | |
| Frequency | |
| Set the sweep marker in Hertz(Hz) (10kHz - 100kHz). | |
SWPMODE
| SWPMODE | |
| Sets the sweep mode to <CONT> or <TRIG>. 0 = CONT, 1 = TRIG. | |
| Mode | |
| Set the sweep mode (0 = CONT, 1 = TRIG). | |
SWPSPNFREQ
| SWPSPNFREQ | |
| Sets the sweep frequency span to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50.25kHz). | |
| Frequency | |
| Set the sweep frequency span in Hertz(Hz) (1uHz - 50.25kHz). | |
SWPTIME
| SWPTIME | |
| Sets the sweep time to <nrf> seconds | |
| Seconds | |
| Set the sweep time in seconds. | |
SWPTRGPER
| SWPTRGPER | |
| Sets the sweep trigger period to <nrf> seconds | |
| Seconds | |
| Set the sweep trigger period in seconds. | |
SWPTRGPOL
| SWPTRGPOL | |
| Sets the sweep trigger slope to; 0 = POS, 1 = NEG. | |
| Slope | |
| Set the sweep trigger slope (0 = POS, 1 = NEG). | |
SWPTRGSRC
| SWPTRGSRC | |
| Sets the sweep trigger source to; 0 = INT, 1 = EXT, 2 = MAN. | |
| Source | |
| Set the sweep trigger source (0 = INT, 1 = EXT, 2 = MAN). | |
SWPTYPE
SYNCOUT
| SYNCOUT | |
| Sets the sync output to; 0 = ON, 1 = OFF. | |
| Sync | |
| Enable/disable sync output (0 = ON, 1 = OFF). | |
SYNCTYPE
TRG
| TRG | |
| This command is the same as pressing the TRIGGER key. | |
TSTRet
| TSTRet | |
| The generator has no self test capability and the response is always 0 <rmt>. | |
WAI
| WAI | |
| Wait for Operation Complete true. As all commands are fully executed before the next is started this command takes no additional action. | |
WAVE
WAVELVL
| WAVELVL | |
| Sets the output waveform level to <nr1> %. (Lower limit: 50 - Upper limit: 100) | |
| Percent | |
| Sets the output waveform level in percent (50 - 100). | |
ZLOAD
