Component: RF Transceiver (nRF24L01) (Wireless)
| Author | Matrix Ltd. |
| Version | 9.0 |
| Category | Wireless |
RF Transceiver (nRF24L01) component
A simple RF communications module based on the 2.4GHz nRF24L01 transceivermodules.
Version information
Library Version, Component Version, Date, Author, Info 9, 9.0, 08-11-24, MW, added missing icon
Example program transmitting a count value, echoing the count and TX status to the UART for debugging.
Example program receiving a value, echoing any received values to the UART for debugging.
CheckRX
| CheckRX | |
| Check the Rx FIFO status register for any new data. Returns 0 = No data Returns 1 = New data available | |
FlushRx
| FlushRx | |
| Tells the RF module to flush the contents of the receive buffer. Returns the status from sending the command. | |
FlushTx
| FlushTx | |
| Tells the RF module to flush the contents of the transmit buffer. Returns the status from sending the command. | |
ReadRegister
| ReadRegister | |
| Reads a single bytes from the selected register. Directly returns the value read back from the register. | |
| Reg | |
| Register address to access | |
ReadRxArray
| ReadRxArray | |
| Reads an array of bytes back from the local Rx buffer. | |
| Data | |
| Byte array to store the received data | |
| NumBytes | |
| Range: 1-32 | |
ReadRxByte
| ReadRxByte | |
| Reads a single byte back from the local Rx buffer. | |
| Index | |
| Byte to read, range 0 - 31 | |
ReadRxFifo
| ReadRxFifo | |
| Reads the Rx FIFO buffer into a local buffer. Use the ReadBuffer/ReadArray macros to collect the individual data bytes. | |
SetRxMode
SetTxMode
WriteRegister
| WriteRegister | |
| Writes a single byte to the selected register. Returns the status of the write command. | |
| Reg | |
| Value | |
WriteTxArray
| WriteTxArray | |
| Writes an array of bytes to the local Tx buffer. | |
| Data | |
| Byte array to write. | |
| NumBytes | |
| Range: 1-32 | |
WriteTxByte
| WriteTxByte | |
| Writes a single byte to the local Tx buffer. | |
| Index | |
| Value | |
WriteTxFifo
| WriteTxFifo | |
| Writes the contents of the local Tx buffer to the Transmit FIFO and transmits. Returns 1 if transmission was sucessful. | |
Please click here to download the component source project: FC_Comp_Source_nRF24L01.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_nRF24L01.fcfx
