Component: ID component:GdiBaseChart
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Author MatrixTSL
Category Creation
Base Chart component
Clear
- NONE Return
Refresh
- NONE Return
AddDataY
- BYTE Series
Which series to add to (1-8)
- FLOAT Value
The data point value
- NONE Return
AddDataXY
- BYTE Series
- FLOAT X
The X coordinate of the data point
- FLOAT Y
The Y coordinate of the data point
- NONE Return
AddDataXYZ
- BYTE Series
- FLOAT X
- FLOAT Y
- FLOAT Z
The Z coordinate of the data point
- NONE Return
AddDataCY
- BYTE Series
- STRING Cat
The category of the data point
- FLOAT Y
- FLOAT Z
- NONE Return
AddPointCXYZ
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
Clear
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
Refresh
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataY
- BYTE Series
- FLOAT Value
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataXY
- BYTE Series
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataXYZ
- BYTE Series
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataCY
- BYTE Series
- STRING Cat
- FLOAT Y
- FLOAT Z
- NONE Return
AddPointCXYZ
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
Clear
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
Refresh
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataY
- BYTE Series
- FLOAT Value
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataXY
- BYTE Series
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataXYZ
- BYTE Series
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataCY
- BYTE Series
- STRING Cat
- FLOAT Y
- FLOAT Z
- NONE Return
AddPointCXYZ
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
Clear
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
Refresh
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataY
- BYTE Series
- FLOAT Value
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataXY
- BYTE Series
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataXYZ
- BYTE Series
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataCY
- BYTE Series
- STRING Cat
- FLOAT Y
- FLOAT Z
- NONE Return
AddPointCXYZ
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
Clear
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
Refresh
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataY
- BYTE Series
- FLOAT Value
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataXY
- BYTE Series
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataXYZ
- BYTE Series
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataCY
- BYTE Series
- STRING Cat
- FLOAT Y
- FLOAT Z
- NONE Return
AddPointCXYZ
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
Clear
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
Refresh
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataY
- BYTE Series
- FLOAT Value
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataXY
- BYTE Series
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataXYZ
- BYTE Series
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataCY
- BYTE Series
- STRING Cat
- FLOAT Y
- FLOAT Z
- NONE Return
AddPointCXYZ
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
Clear
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
Refresh
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataY
- BYTE Series
- FLOAT Value
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataXY
- BYTE Series
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataXYZ
- BYTE Series
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
AddDataCY
- BYTE Series
- STRING Cat
- FLOAT Y
- FLOAT Z
- NONE Return
AddPointCXYZ
- STRING Cat
- FLOAT X
- FLOAT Y
- FLOAT Z
- NONE Return
General
Type
Stacking
Data Between Ticks
Show Data Info Box
Radial grid lines
Set false for radar, true for polar
Optimised Data
Use Arrays
Fixed Interval Width Mode
Interval Width
Values Per Interval
Responsiveness
The number of value updates before a redraw is forced (0 = no redraws)
Title
Chart title
Style
Fill Gradient
Transparency
Single Colour
Bubble Scale
Exploded
Hole Size
Rotation
Viewing Depth
X-axis
Name
Show Grid
Show Interlacing
Auto-scale
Start
End
Logarithmic
Scalable
Y-axis
Name
Show Grid
Show Interlacing
Auto-scale
Start
End
Logarithmic
Scalable
Y-axis (secondary)
Name
Show Grid
Show Interlacing
Auto-scale
Start
End
Logarithmic
Scalable
Data Labels
Show
Show Category
Show Value
Show Percentage
Show Series
Angle
Position
Legend
Position
Draw Border
Series
Select Series
Series1
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series2
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series3
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series4
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series5
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series6
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series7
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series8
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Temporary Stuff
nSeries
dXVal
dYVal
dY1Val
sYCat
fnClearData
fnAddValue
fnAddValueXY
fnAddCatValue
fnAddValueCXYY1
fnAddValueXYY1
fnAddOptimisedData
fnGetValue
fnGetValueXY
fnRefreshChart
