Component: LCD (Grove - UART) (Alphanumeric)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 2.0
Category Alphanumeric
LCD (Grove - UART) component
Standard alphanumeric LCD based on the Grove display module.
Please click here to download the component source project: FC_Comp_Source_LCD_Grove_Uart.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_Grove_Uart.fcfx
BacklightControl
BacklightControl
- BYTE State
0=Backlight Off, 1=Backlight On
Clear
Clear
ClearLine
ClearLine
- BYTE Line
ClearSim
ClearSim
Cursor
Cursor
- BYTE x
- BYTE y
PrintAscii
PrintAscii
- BYTE character
PrintFloat
PrintFloat
- FLOAT Number
- BYTE DecimalPlaces
PrintFormattedNumber
- ULONG Number
- BOOL Format
0=Signed, 1=Unsigned
Allows you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
PrintString
PrintString
- STRING Text
ScrollDisplay
ScrollDisplay
- BYTE position
Number of positions to scroll the display
- BYTE direction
Direction to scroll the display: 0=Left, 1=Right
Start
Start
Startup routine required by the hardware device.
LCD Configuration
Rows
Columns
TX
Use RX
Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
Baud Options
Component Label
Component Label Scale
Text Colour
Colour of the font characters drawn on the display
Text Background
Display Background
Console Columns
Data Source
