| Author
Matrix TSL
| Version
2.1
| Category
Comms: System
Modbus Master (SCADA) component
Modbus component for talking to Modbus compatible hardware via RS232 or RS485.
Please click here to download the component source project: FC_Comp_Source_Modbus_SCADA.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_Modbus_SCADA.fcsx
ChangeFrameType
ChangeFrameType
| Default frame type is the type set in the component properties.
- BYTE
Type
| 0 = Modbus RTU / 1 = Modbus ASCII
GetResponse
GetResponse
| Collects as much incoming data as possible and stored into the response buffer. The number of bytes received will be stored into location 0 of the response buffer. Return value indicates validity of incoming CRC. 0 = OK, 1 = CRC fail, 255 = No Data
- BYTE
GetResponseByte
GetResponseByte
| Reads a byte from the last received response. The Index parametes specifies which byte to read back.
- BYTE
Index
| 0=NumBytes, 1=SlaveAddress, 2=FunctionCode/ExceptionCode, 3=DataBytes, 4=data0, 5=data1, ..
- BYTE
GetResponseInt
GetResponseInt
| Reads a 16-bit value from the last received response. The Index parametes specifies the byte index of the value to read back.
- BYTE
Index
| 4=data0, 6=data1, 8=data2, ..
- UINT
| Starts up the UART to allow communications
ReadAnalogInput
| This command requests the analogue input register values starting from the start RegAddress and going through to RegAddress plus RegCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
| The ID of the MODBUS slave
- UINT
RegAddress
| Input Address: 0=10001, 1=10002, 2=10003, ...
- UINT
RegCount
| Number of consecutive inputs to read, starting from RegAddress
- BYTE
ReadCoil
ReadCoil
| This command requests the ON/OFF status of discrete coils starting from the start CoilAddress and going through to CoilAddress plus CoilCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
CoilAddress
| Coil Address: 0=Coil1, 1=Coil2, 2=Coil3, ...
- UINT
CoilCount
| Number of consecutive coils to try and read
- BYTE
ReadDigitalInput
| This command requests the ON/OFF status of discrete inputs starting from the start DataAddress and going through to DataAddress plus DataCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
DataAddress
- UINT
DataCount
- BYTE
ReadHoldingRegister
ReadHoldingRegister
| This command requests the analogue holding register values starting from the start RegAddress and going through to RegAddress plus RegCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
RegAddress
| Address: 0=40001, 1=40002, ...
- UINT
RegCount
| Number of consecutive registers to read, starting from RegAddress
- BYTE
SetCoil
SetCoil
| This command writes the contents of a discrete coil at the location CoilAddress. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
CoilAddress
- BYTE
CoilState
| 0=Off, 1=On
- BYTE
SetCoils
SetCoils
| This command writes the contents of a series of discrete coils at the location starting at CoilAddress through to CoilAddress + CoilCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
CoilAddress
- UINT
CoilCount
- BYTE
CoilData
| An array of bytes each containing 8 1-bit coil values
- BYTE
SetHoldingRegister
SetHoldingRegister
| This command writes the contents of a holding register at the location RegAddress. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegValue
| Value to send to the selected register
- BYTE
SetHoldingRegisters
SetHoldingRegisters
| This command writes the contents of several holding registers starting at the location RegAddress through to location RegAddress + RegCount . Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegCount
| Number of consecutive registers to write, starting from RegAddress
- UINT
RegValue
| Array of values to send to the registers
- BYTE
Modbus Properties
Frame Type
| Switches between RTU and ASCII forms of Modbus
Receive Buffer Size
| Maximum number of bytes the receive buffer can hold
Slave ID Bytes
| Number of bytes used when passing a slave ID, usually 1 but sometimes 2
Silent Interval
| Configures how much time to wait after each master modbus command before another command can be sent. A silent interval of 60ms minimum is required in order to guarentee successful reception of the next transmission. 0=No Delay 60 = 60mS - Default Range : 0 - 65535
UART Receive Timeout
| Amount of time to wait before timing out when listening for a slave's response. Range: 0 - 255. 0 = Don't Wait 1 - 254 = X ms 255 = Wait Forever
Receive Timeout Count
| Number of timeouts in a row to wait for until we decide the slave is not responding or finished responding to a message. Range: 0 - 255 0 = First Timeout Only 1 = First Timeout + 1 2 = First Timeout + 2
Runtime Properties
| A text label to appear on the Modbus panel object.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port Injector - Routes the communication data via a data injector component on the Panel.
COM Port
| Lists all the current available COM port hardware on your PC.
Refresh Ports
| COM port data rate in bits per second
