Component: GLCD (ST7789V) (Graphical Color)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 1.6
Category Graphical Color
GLCD (ST7789V) component
Graphical display component designed to work with the ST7789V 16-bit colour graphical controller IC.
Version information
16, 1.0, 11-05-26, BR, Fixed a problem with fast pixel buffer being increased
BPlot
BPlot
- UINT X1
- UINT Y1
BacklightOff
BacklightOff
Switches off the backlight
BacklightOn
BacklightOn
Switches on the backlight
ClearDisplay
ClearDisplay
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT X
Center X coordinate
- UINT Y
Center Y coordinate
- UINT Radius
Radius, distance of edge from the centre coordinates
- FLOAT StartAngle
Angle to start drawing, in degrees
- FLOAT EndAngle
Angle to end drawing, in degrees
- UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBezier
DrawBezier
Draws a quadratic Bezier curve with the current foreground colour from pixel location X0, Y0 to pixel location X2, Y2 using control point CX, CY.
- UINT X0
Start X coordinate
- UINT Y0
Start Y coordinate
- UINT CX
Control point X coordinate
- UINT CY
Control point Y coordinate
- UINT X2
End X coordinate
- UINT Y2
End Y coordinate
- UINT Resolution
Number of segments to approximate the curve, 0 chooses an automatic value based on curve size.
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Draws a rectangle with rounded corners
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- UINT Radius
- BYTE Transparent
- BYTE Solid
FastPlot
FastPlot
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetBackgroundColour
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
Window
Window
Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed.
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Dimensions
Pixel Width
Pixel Height
X Offset
Horizontal offset before the active display pixels.
Y Offset
Vertical offset before the active display pixels.
Colour
Monochrome
Foreground Color
Background Color
Invert Colours
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Use SPI
No - Use dedicated IO pins to drive the display Yes - Use the micrcontroller's SPI peripheral to drive the display
SPI Settings
SPI Channel selector
Prescale
Prescale option selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
Queue Fast Pixels
An optimisation for ESP32 based devices where Fast pixels are queued up and all drawn together. Acts to speed up writes to the display when drawing lines, rectangles, ellipses, circles, none transparent strings etc.
Pixel Queue Size
Defines how many fast pixels can be stored in the queue. The larger the number the more RAM used but the quicker the speed to write to the display. Each pixel = 2 bytes.
Use CS
Toggle CS
Selects if the chip select pin is automatically toggled or left selected. Yes - Slightly slower but allows pins to be multiplexed with other devices. No - Slightly faster.
Chip Select
Chip select pin connection
DC
Data/Command Pin
Use Reset
Reset
Reset Pin
Use Backlight
Backlight
Backlight Pin
Fonts
Font Count
Font 0
Font
Bytes Required
Number of bytes required in program memory to store the selected font.
Character Spacing
Sets the number of blank pixels between each character when printing text.
Space Width
Component Label
Component Label Scale
Physical Orientation
Simulate Comms
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
Please click here to download the component source project: FC_Comp_Source_GLCD_ST7789V.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7789V.fcfx
