Component: Bluetooth (RN4677) (RN4677) (Wireless)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Author Matrix Ltd.
Version 1.4
Category Wireless
Bluetooth (RN4677) component
Low level routines for controlling a Microchip RN4677 Bluetooth Module. Also available in the form of the BL0170 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware UART channel.
Please click here to download the component source project: FC_Comp_Source_Bluetooth_RN4677.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Bluetooth_RN4677.fcfx
ConnectToMAC
ConnectToMAC
Connects to a specific Bluetooth MAC address. Waits up to 5 seconds for connection to be established. Returns 1 if connection was successful.
- STRING MACAddress
MAC Address of the Bluetooth Device we wish to connect to
- BOOL Return
EnterCommandMode
EnterCommandMode
Enters command mode allowing commands to be sent using the SendCommand macro. Returns: 0 = No Reply / 1 = Command Mode OK
- BOOL Return
GetMACAddress
GetMACAddress
Gets the local Bluetooth device MAC address.
- STRING Return
Sets up the Bluetooth module including: - Enabling the UART - Configuring the module (Name / Key / etc) Returns 1 for OK and 0 for no reply.
LeaveCommandMode
LeaveCommandMode
Leaves command mode allowing data to be passed back and forth,
ReadString
ReadString
Copies the incoming data from the data string array to a local string variable.
- BYTE NumBytes
Maximum number of bytes to try and read
- STRING Return
ReceiveByte
ReceiveByte
Receives a single data byte from the Bluetooth module. 0-255 - Valid Data / 256 signifies no data available.
- UINT Timeout
Amount of time to wait in milliseconds 0=Wait forever
SendByte
SendByte
Sends a single data byte out to the Bluetooth module.
- BYTE Data
SendCommand
SendCommand
Sends a command string to the Bluetooth module. 0 = Command sent ok, 255 = No Reply
- STRING Command
- BYTE SendCR
- BYTE DiscardReply
0=Do not touch the reply, 1=Wait for reply and remove from buffer
SendString
SendString
Sends a string to the Bluetooth module.
- STRING Text
- BYTE SendCR
WaitForStringValue
WaitForStringValue
Allows us to wait and check for an incoming value. Returns 1 if the string value is found otherwise returns 0.
- STRING Value
String value to look for
- UINT Timeout
Length of time to wait in milliseconds
- BOOL Return
Bluetooth Settings
Init Details
Allows the Bluetooth device name and key to be automatically assigned on initialise.
Device Name
Sets the friendly name of the Bluetooth device.
Pair Key
Discoverable
Is the Bluetooth module discoverable by default?
Reply Timeout
Specifies the amount of time to wait for incoming data before timing out in milliseconds. Default 2000 = 2 seconds.
RX Buffer Size
Amount of RAM memory to dedicate to receiving responses and incoming data from the BT module. Default 40
Baud Options
TX
TX Remap Pin
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
RX Remap Pin
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Use Flow Control
Reset Pin
Simulate Comms
Console Columns
Data Source
