| Author
Matrix TSL
| Version
1.6
| Category
Movement Orientation
Magnetometer 3-Axis (QMC5883L) component
QMC5883L 3-Axis Magnetometer sensor Useful for working out data such as compass orientation.
Please click here to download the component source project: FC_Comp_Source_Magnetometer_QMC5883.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Magnetometer_QMC5883.fcfx
Here is a very simple demonstration on how to use the sensor to read X, Y, Z magnetometer data from the sensor.
QMC5883L Demo
CollectXYZData
CollectXYZData
| Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
- BYTE
Axis
- INT
| Sets up up the communication bus and initialises the accelerometer module.
Read_Bearing
Read_Bearing
| Reads the current sensor compass bearing based on degrees CW from magnetic north. Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West Requires the ArcTan floating point function to be available to work correctly. Supported on AVR, 16-bit
- BYTE
NumSamples
| The number of readings to base the bearing on
- UINT
Read_Register
Read_Register
| Reads a value from a register on the accelerometer.
- BYTE
Reg
- BYTE
SimSetCompass
SimSetCompass
| Allows the XYZ slider values to be set via the simulation
- INT
X
- INT
Y
- INT
Z
UpdateCompassData
UpdateCompassData
| Reads from the compass and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
- BYTE
Write_Register
Write_Register
| Writes a data value to a specific register on the accelerometer
- BYTE
Reg
- BYTE
Data
- BYTE
Bit Depth
Compass Data Rate
| Sets the output conversion rate.
Oversample Ratio
Compass Scale
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
SDA
SCL
Use RDY Pin
Simulate Comms
| Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the I2C CAL component - API etc
