Component: E-Blocks 3 (USB Comms) (E-blocks 3)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 3.0
Category E-blocks 3
E-Blocks 3 (USB Comms) component
Low level routines for connecting the E-blocks 3 hardware to the computer using a USB COM port serial data connection.
ChangeHWBaud
ChangeHWBaud
Changes the hardware UART baud rate allowing for dynamic speed changes.
- BYTE NewBaud
0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200, 8=250000
Sets up the RS232 peripheral, must be called at the start of your program or at least before you start calling any other RS232 macros.
ReceiveBinary16Bit
ReceiveBinary16Bit
Receives a binary 16-bit value split across two bytes.
- BOOL MSBfirst
0=Least significant byte first, 1=Most significant byte first
- BYTE Timeout
Max amount of time in ms to wait between bytes
ReceiveBinary32Bit
ReceiveBinary32Bit
Receives a binary 32-bit value split across four bytes.
- BOOL MSBfirst
- BYTE Timeout
- ULONG Return
ReceiveBinaryFloat
ReceiveBinaryFloat
Receives a binary 32-bit floating point value split across four bytes.
- BOOL MSBfirst
- BYTE Timeout
- FLOAT Return
ReceiveByteArray
ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
- BYTE Data
Array to store the incoming data
- UINT NumBytes
Maximum number of bytes to try and receive
- BYTE Timeout
ReceiveChar
ReceiveChar
Attempts to receive a single packet from the UART interface.
- BYTE Timeout
Time to wait in milliseconds for valid data before returning, 0=Dont wait, 255=Wait forever.
- INT Return
ReceiveFloat
ReceiveFloat
Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE Timeout
Max time in ms to wait in between bytes
- BOOL IgnoreData
0=Dont ignore any data, 1=Ignore any initial none numeric data
- FLOAT Return
ReceiveHexNumber
ReceiveHexNumber
Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
- BYTE Timeout
- BOOL IgnoreData
- BOOL Prefix
Look for prefix before receiving, 1=0xFF, 0=FF
- ULONG Return
ReceiveINTArray
ReceiveINTArray
Receives an array of 16-bit INT/UINT values and returns the number of values received.
- UINT Data
- UINT NumValues
Maximum number of values to try and receive
- BOOL MSBfirst
- BYTE Timeout
ReceiveNumber
ReceiveNumber
Attempts to receive a number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE Timeout
- BOOL IgnoreData
- LONG Return
ReceiveString
ReceiveString
Attempts to receive a string of bytes from the UART interface.
- BYTE Timeout
- UINT NumBytes
The number of bytes to try and receive, ideally your string variable should have at least 1 more byte to store the null termination byte
- STRING Return
SendBinary16Bit
SendBinary16Bit
Sends out a 16-bit binary value split across two bytes.
- UINT Value
- BOOL MSBfirst
SendBinary32Bit
SendBinary32Bit
Sends out a 32-bit binary value split across four bytes.
- ULONG Value
- BOOL MSBfirst
SendBinaryFloat
SendBinaryFloat
Sends out a 32-bit binary floating point value split across four bytes.
- FLOAT Value
- BOOL MSBfirst
SendByteArray
SendByteArray
Transmits an array of bytes via the UART peripheral
- BYTE Data
Data to transmit
- UINT NumBytes
Number of bytes to send from the array
SendChar
SendChar
Sends out a single packet from the UART interface.
- INT Char
SendFloat
SendFloat
Sends out a floating point number as an ASCII String from the UART interface.
- FLOAT Number
SendHexNumber
SendHexNumber
Sends out a number as an ASCII hexadecimal String from the UART interface.
- ULONG Number
- BYTE NumChars
Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
- BOOL Prefix
Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
SendINTArray
SendINTArray
Transmits an array of 16-bit INT/UINT values via the UART peripheral
- UINT Data
Data to transmit
- UINT NumValues
Number of 16-bit values to send from the array
- BOOL MSBfirst
SendNumber
SendNumber
Sends out a number as an ASCII String from the UART interface.
- LONG Number
SendString
SendString
Sends out a string of bytes from the UART interface.
- STRING Data
Comms Settings
TX
RX
Textual label shown on the component I/O flasher
Console Format
Controls if the data is shown as a log with time and date stamps or just as raw data
Console Columns
Data Source
Please click here to download the component source project: FC_Comp_Source_EB3_USB_COM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EB3_USB_COM.fcfx
