Component: G Code Parser ()
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 1.1
Category
G Code Parser component
A set of routines to allow a G-Code type file to be parsed a line at a time and the coordinates to be collected. Simulates the G commands via a simulation only 3D printer component but can also be used to pass values to actual hardware.
Please click here to download the component source project: FC_Comp_Source_G-Code_Parser.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_G-Code_Parser.fcfx
GetAxis
GetAxis
Returns the value of the Axis generated from the ParseCommand function. 0 = Read X, 1 = Read Y, 2 = Read Z
- BYTE Axis
Specifies which axis to read 0/'x'/'X' - 1/'y'/'Y' - 2/'z'/'Z'
- FLOAT Return
GetCoordinateMode
GetCoordinateMode
Returns the current coordinate mode. 0 = Absolute 1 = Relative
Parse_G_Command
Parse_G_Command
- STRING Command
Bed Color
Print Color
Print Speed
Print Type
Print Size
Print Shape
Max Print Dimensions
X Width
Y Length
Z Height
