Component: Accelerometer 3-Axis (LIS3DHTR) (LIS3DHTR) (Movement Orientation)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA;"" to "class="mtx-class-propfolder"")
Version 1.6
Category Movement Orientation
Accelerometer 3-Axis (LIS3DHTR) component
LIS3DHTR 3-Axis Accelerometer sensor.
Please click here to download the component source project: FC_Comp_Source_Accelerometer_LIS3DHTR.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Accelerometer_LIS3DHTR.fcfx
CollectXYZData
CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
- BYTE Axis
- INT Return
Sets up up the communication bus and initialises the accelerometer module. Returns 1 for success and 0 for fail.
Read_Register
Read_Register
Reads a value from a register on the accelerometer.
- BYTE Reg
SimReset1G
SimReset1G
SimSetAccelerometer
SimSetAccelerometer
Allows the XYZ slider values to be set via the simulation
- INT X
- INT Y
- INT Z
UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
Write_Register
Write_Register
Writes a data value to a specific register on the accelerometer
- BYTE Reg
- BYTE Data
Bit Depth
Accel Data Rate
Accel Scale
SA0 Pin
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Simulate Comms
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the I2C CAL component - Injector etc
