Component: Matrix Cap Touch Display (Development)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA;"" to "class="mtx-class-propfolder"")
Category Development
Matrix Cap Touch Display component
A component to drive the capacitive touch display module as used in EM, 3PH PSU, CNC
Auto Detect Port Number
This example auto detects and opens a COM Port based on preassigned USB Identifiers VID/PID.
For a known device the VID and PID can be found via Windows device manager.
Auto Detect Example
BluetoothConnectionStatus
Checks to see if the Bluetooth is connected to a master device
- BOOL Return
BluetoothInit
BluetoothInit
Startup up Bluetooth communications and assigns a friendly name
- STRING Name
Friendly device name
BluetoothReceiveArray
Read an array of bytes from the Bluetooth connection Returns the number of bytes read from the file
- BYTE Data
- UINT Count
BluetoothSendArray
BluetoothSendArray
Send an array of bytes via Bluetooth
- BYTE Data
- UINT Count
BluetoothUninit
BluetoothUninit
Shots down Bluetooth communications
ClearDisplay
ClearDisplay
Clears the display and resets the button count
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT X1
Center X coordinate
- UINT Y1
Center Y coordinate
- UINT Radius
Radius, distance of edge from the centre coordinates
- UINT StartAngle
Angle to start drawing, in degrees
- UINT EndAngle
Angle to end drawing, in degrees
- UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Autofill
- BYTE Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBitmap
DrawBitmap
Draws a bitmap image loaded from the SD card FileInit must be called first to ensure the File System is setup.
- STRING Filename
Text label to draw on the button
- UINT X1
- UINT Y1
- BYTE Transparency
Set the button type
- BYTE Orientation
- BYTE Flip
DrawButton
DrawButton
Draws a button or slider that can be touched
- UINT X
- UINT Y
- UINT Width
- UINT Height
- BYTE Type
Set the button type: 0=Rect, 1=RoundRect, 2=Ellipse, 3=Bitmap, 4=VSlider, 5=HSlider, 6=RVSlider, 7=RHSlider
- BYTE Font
Range: 0-3
- BYTE ThemeIndex
- STRING Text
- BYTE SliderMode
0=HighlightOnly, 1=Highlight and Lowlight
DrawEllipse
DrawEllipse
Draws a ellipse centered around X,Y with radius X2,Y2
- UINT X1
- UINT Y1
- UINT Width
- UINT Height
- BOOL Transparent
When Solid=0 - 0 = Fill with Background / 1 = No Fill
- BOOL Solid
0=Foreground for the outline only, 1=Fill with foreground
DrawGraph
DrawGraph
Draws a line graph area on the display with or without grids. Uses the current foreground / background colours
- UINT X
X coordinate for top left of graph
- UINT Y
Y coordinate for top left of graph
- UINT Width
Width of graph in pixels
- UINT Height
Height of graph in pixels
- INT MinX
Minimum X Value - XY type only
- INT MaxX
- INT MinY
Minimum Y Value
- INT MaxY
Maximum Y Value
- BYTE Type
0=Scrolling, 1=XY
- BYTE NumPoints
Number of points per line - Scrolling Type Only
- BYTE ThemeIndex
- BYTE XMajor
Major subdivisions count
- BYTE XMinor
Minor subdivisions count
- BYTE YMajor
- BYTE YMinor
DrawLine
DrawLine
Draws a single pixel thickness line
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawPixel
DrawPixel
Draws a single pixel in the foreground colour at X,Y
- UINT X1
- UINT Y1
DrawQRCode
DrawQRCode
Draws a QR code with the specified data string embedded. Default size for the QR code is 33 x 33 @ a scaler of 1. Can be used to store up to 78 characters Recommend a scaler of 3 or 4. QR code should be drawn with a decent clear border around it to make it easier to scan.
- UINT X
Left hand side pixel coordinate
- UINT Y
Top side pixel coordinate
- BYTE Scaler
Size of each block in pixels
- STRING Text
Data to embed into the QR code. e.g. "www.flowcode.co.uk/EM"
DrawRectangle
DrawRectangle
Draws a rectangle from X1,Y1 to X2,Y2
- UINT X1
- UINT Y1
- UINT Width
- UINT Height
- BOOL Transparent
- BOOL Solid
DrawRoundedRectangle
Draws a rectangle with rounded corners
- UINT X1
- UINT Y1
- UINT Width
- UINT Height
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawString
DrawString
Draws a string at the specified location in the specified font
- UINT X1
- UINT Y1
- STRING Data
- BYTE Font
- BOOL Transparent
0=Draw background, 1=Do not draw background
- BYTE Align
0=Left, 1=Center, 2=Right
FileCreate
FileCreate
Creates an empty file on the file system
- STRING Filename
FileDelete
FileDelete
Deletes a file from the file system
- STRING Filename
FileInit
FileInit
Starts up the FAT file system access function for the SD card 0=OK
FileOpen
FileOpen
Opens a file ready for reading or writing
- STRING Filename
FileReadArray
FileReadArray
Read an array of bytes from the current open file Returns the number of bytes read from the file
- BYTE Data
- UINT Count
FileWriteArray
FileWriteArray
Write an array of bytes to the current open file
- BYTE Data
- UINT Count
FolderOpen
FolderOpen
Navigates the current directory to a folder We can use ",," to go up a level or "root" to go back to the root.
- STRING Filename
GetAPIVersion
GetAPIVersion
GetCardPresent
GetCardPresent
Checks to see if a SD card is inserted 1=Card Present, 0=No Card Present
- BOOL Return
GetLastButtonPress
GetLastButtonPress
Gets the button index of the last valid button press. 255 = No new touch detected
GetLastRawTouchCoordinate
Gets the coordinates of the last touch. -1 = no new touch data available.
- INT XY
GetSliderValue
GetSliderValue
Gets the value of one of the slider buttons
- BYTE ButtonID
the ID of the slider button you want to read
- FLOAT Return
ListenForTouch
ListenForTouch
Enables a screen touch to interrupt the microcontroller using a UART RX interrupt. The master microcontroller must call this function and then enable UART RX interrupt.
- UINT State
0=Off, 1=On
- BOOL ButtonOnly
0=All Touches, 1=Buttons/Sliders only
SetBackgroundColour
SetBackgroundColour
Sets the background draw colour
- BYTE R
- BYTE G
- BYTE B
SetBacklightBrightness
Sets the brightness of the backlight
- BYTE Brightness
0=Off, 255=Max
SetBitmapTransparencyColour
Sets the RGB colour to use as a transparent mask when drawing bitmaps
- BYTE R
- BYTE G
- BYTE B
SetButtonIntervalPeriod
Sets the button repress interval in steps of 10ms
- UINT Period
Multiple of 10ms, default 50 = 500ms
SetColourPallet
SetColourPallet
Sets the colour pallet for drawing buttons
- BYTE ThemeIndex
Range: 0 to 9
- BYTE ForegroundR
- BYTE ForegroundG
- BYTE ForegroundB
- BYTE BackgroundR
- BYTE BackgroundG
- BYTE BackgroundB
- BYTE HighlightR
- BYTE HighlightG
- BYTE HighlightB
- BYTE LowLightR
- BYTE LowLightG
- BYTE LowLightB
SetFontScaler
SetFontScaler
- BYTE XScaler
Width Multiplier Range: 1 to x
- BYTE YScaler
Height Multiplier Range: 1 to x
SetForegroundColour
SetForegroundColour
Sets the foreground draw colour
- BYTE R
- BYTE G
- BYTE B
SetGraphData
SetGraphData
- BYTE TraceIndex
Range: 0-5 Max 6 traces
- INT X
X value - XY Graph Type Only
- INT Y
Y value
SetOrientation
SetOrientation
Sets the display orientation
- BYTE Orientation
Range: 0 - 3
SetSliderValue
SetSliderValue
Sets the value of one of the slider buttons
- BYTE ButtonID
- FLOAT Value
Range: 0 to 1
UpdateButtonText
UpdateButtonText
Redraws the selected button with the new text
- BYTE ButtonIndex
Range: 0 to NumButtons -1
- STRING Text
UpdateButtonTheme
UpdateButtonTheme
Redraws the selected button in a new theme
- BYTE ButtonIndex
- BYTE ThemeIndex
Range: 0 to 9
WifiAcceptClose
WifiAcceptClose
Stops incoming socket requests from being accepted
WifiAcceptOpen
WifiAcceptOpen
Allows incoming socket requests to be accepted
WifiConnectToSSID
WifiConnectToSSID
Connects to a remote WIFI network
- STRING SSID
- STRING Password
WifiCreateAccessPoint
Creates a local access point
- STRING SSID
- STRING Password
- BYTE Channel
Range 1-14
- BYTE Encryption
Range 0-4 - 0=Open, 1=WEP, 2=WPAPSK, 2=WPA2PSK 3=WPAWPA2PSK
WifiDisconnect
WifiDisconnect
Disconnect from the current socket
WifiInit
WifiInit
Startup up WIFI communications
WifiReadIP
WifiReadIP
Collects the IP address from the WIFI as a string.
- STRING Return
WifiReceiveArray
WifiReceiveArray
Read an array of bytes from the WIFI connection Returns the number of bytes read from the file
- BYTE Data
- UINT Count
WifiScan
WifiScan
Scans the WIFI network and returns the number of networks detected
WifiScanEncryptionMode
Collects the encryption mode from one of the results of the Scan. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE Index
Range: 0 - (Num Returned By WifiSSIDScan) - 1
WifiScanSSID
WifiScanSSID
Collects the SSID network name from one of the results of the Scan.
- BYTE Index
- STRING Return
WifiScanSigStrength
WifiScanSigStrength
Collects the signal strength from one of the results of the Scan
- BYTE Index
- INT Return
WifiSendArray
WifiSendArray
Send an array of bytes via WIFI
- BYTE Data
- UINT Count
WifiSocketClose
WifiSocketClose
Close a socket
WifiSocketConnect
WifiSocketConnect
Connect to a remote socket
- STRING Address
- UINT Port
WifiSocketListen
WifiSocketListen
Listens to a socket for incoming data
- UINT Port
WifiSocketOpen
WifiSocketOpen
Opens a socket
WifiUninit
WifiUninit
Shots down Wifi communications
Rx Retry Count
Number of times to retry and collect a reply from the display
Rx Timeout
Amount of time to wait for each return byte
TX
TX Remap Pin
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
RX Remap Pin
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Simulation Type
COM Port
Lists all the current available COM port hardware on your PC.
Please click here to download the component source project: FC_Comp_Source_CapTouchDIsplay.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CapTouchDIsplay.fcfx
