Component: IO Expander (MCP23S17) (MCP23S17) (General Input)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA;"" to "class="mtx-class-propfolder"")
Category General Input
IO Expander (MCP23S17) component
Provides 16 digital input/output pins arranged into two 8-bit ports using a SPI bus connection. Multiple expanders can be connected to the same SPI peripheral by means of individual chip select pins.
Please click here to download the component source project: FC_Comp_Source_MCP23S17.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MCP23S17.fcfx
ConfigureInversion
ConfigureInversion
Configures the pin inversion for the two ports. Disabled on all pins by default.
- BYTE PortA
Port A inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE PortB
Port B inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ConfigurePullups
ConfigurePullups
Configures the pullups for the two ports. Disabled on all pins by default.
- BYTE PortA
Port A pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE PortB
Port B pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadPort
ReadPort
Reads a value to one of the ports with a mask. Configures the masked bits to be inputs before reading the input value.
- BYTE Port
0=PortA, 1=PortB
- BYTE Mask
Allows port bits to be modified without effecting other bits, 255 = write full port.
ReadPortPin
ReadPortPin
Reads a single port pin from one of the ports. Configures the pins to be an input before reading the input value. Returns 0 or 1 corresponding to the value on the port pin.
- BYTE Port
0=PortA, 1=PortB
- BYTE Pin
Port pin to read. Range: 0-7
ReadRegister
ReadRegister
Reads an 8-bit value from a register on the I/O expander device.
- BYTE Address
Register address to write to. Range: 0-15
WritePort
WritePort
Writes a value to one of the ports with a mask. Configures the masked bits to be outputs before writing the output value.
- BYTE Port
0=PortA, 1=PortB
- BYTE Mask
- BYTE Value
Value to write. Range 0-255
WritePortPin
WritePortPin
Writes a single port pin on one of the ports. Configures the pins to be an output before writing the input value.
- BYTE Port
0=PortA, 1=PortB
- BYTE Pin
- BYTE Value
Value to output on the selected pin. Range: 0-1
WriteRegister
WriteRegister
Writes an 8-bit value to a register on the I/O expander device.
- BYTE Address
- BYTE Value
Value to write. Range: 0-255
SPI Communications
External Address
Selects the value of the three address pins for the MCP23S17.
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Use Reset
API
