Component: Gyroscope 3-Axis I2C (L3GD20) (Movement Orientation)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA;"" to "class="mtx-class-propfolder"")
Category Movement Orientation
Gyroscope 3-Axis I2C (L3GD20) component
Interface to the L3GD20 three axis digital gyroscope. Panel GUI can be used to simulate incoming data for testing.
Please click here to download the component source project: FC_Comp_Source_Gyroscope_L3GD20_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Gyroscope_L3GD20_I2C.fcfx
GetGyroReading
GetGyroReading
Collects one of the gyroscope readings from the last sample.
- BYTE Axis
0=X, 1=Y, 2=Z
- INT Return
Initialise the component. Returns 0 if successful
ReadRegister
ReadRegister
Read the data byte at the given address of the device
- BYTE Reg
address of the register to be read
SampleDevice
SampleDevice
Reads the Axis data from the device.
WriteRegister
WriteRegister
Writes the data byte to the given address of the device. Returns 0 if successful
- BYTE Reg
address of register to be written with data byte
- BYTE data
data byte to be written to device register
Output Data Rate
Specifies the gryoscope sample data rate
Full Scale Selection
Specifies the maximum angular speed which the sensor can measure in degrees per second
Bandwidth Selection
Linked with data rate, See device datasheet table 21.
Filter Enable
Enables automatic internal filtering on the gyro data
X Axis
Enables or disables the selected axis allowing it to generate data or be switched off to save power.
Y Axis
Z Axis
Connection
Address Pin
The state of the SDO address pin. 0 = Connected to GND 1 = Connected to VCC
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Simulate Comms
Controls where the simulation data comes from. Component GUI - Data comes from the sliders on the component panel GUI API - Comms data is sent and received via an API component
